12-08-2015, 08:17 PM | #1 |
Rep 904
Oil leak?
I noticed a burning smell coming into my cabin so I pulled over. Smelled like burning 12V wires at first, but a bit more foul. I opened the hood and noticed a puff of white smoke coming out from the engine where I circled the picture. I'm assuming it's leaking oil that's being burned off? I've never actually smelled burning oil, so I don't know what it's supposed to smell like. The puff of white smoke is visible for about 2 seconds every minute or so. Would this indicate a leak in the valve cover gasket or the oil filter housing gasket?
12-08-2015, 09:11 PM | #2 |
Rep 758
Classic valve cover leak point. Oil filter housing is on the other side of the engine so you don't get much oil burning from it leaking, just lots of oil everywhere.
Top Down 365
12-08-2015, 09:48 PM | #3 |
Rep 2,547
Maybe some of the excess Armorall dripped onto the exhaust manifold
Seriously though, I just replaced a valve cover gasket on a 525i that was leaking and burning oil when it dripped on the exhaust manifold in the same area. It's an easy job, I recommend doing the spark plugs at the same time if needed since they're easily accessible while the coil packs are out. I also recommend using a BMW gasket set and bolt seals. If you have high mileage (100k) rebuild the VANOS since it's right there. |
12-08-2015, 10:02 PM | #4 | ||
Rep 904
12-28-2015, 10:52 AM | #5 |
Rep 904
My parts came in this weekend, but I just realized I forgot to buy a sealant. A google search is coming up with a few different recommendations - some say to use a gasket sealer, some say to use a gasket maker, some say to use a sensor-safe, high-temp RTV. Are these basically all the same? If possible I just want to get 1 tube that I can use for many different applications such as my valve cover gaskets on various cars and my top motor when it eventually fails.
Permatex® Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker Permatex Ultra Rubber Gasket Sealant & Dressing Permatex High-Temp Red RTV Silicone Gasket |
12-28-2015, 11:01 AM | #6 |
Rep 758
Use the Ultra Black. It can be used as a sealer, a gasket maker, it's sensor safe and it's got really good oil resistance at high temperatures. In this case you're using it as a sealer so only a thin, light coat is required. I've used it with good results on M52 and M54 engines.
Top Down 365
12-28-2015, 11:37 AM | #7 | |
Rep 904
12-28-2015, 12:03 PM | #8 |
Rep 758
Yes, you can use it for the top motor housing, provided it hasn't turned rock hard by then.
Top Down 365
12-28-2015, 12:16 PM | #9 |
Rep 2,547
I used Hylomar® Universal Blue. It doesn't harden so if/when the valve cover needs come back off it will easily release. Any high quality gasket maker will work though. I have used Permatex Ultra Blue with good results. Only a small amount is needed at the corners of the half moons and the VANOS to head junction. Using allot is NOT better...
12-28-2015, 11:07 PM | #10 |
636
Rep 3,124
I think it may have been Ron Stygar that crossed the OEM sealant to 3M 08661.
I've used it 4-5 times. No leaks, stays pliable, and peals off easily.
