      02-16-2015, 01:18 PM   #1
ccameselle
Drives: 2007 Z4 Si
2007 Z43.0Si dtc button not doing anything
Hello everyone, I just got a new to me 2007 Z4 3.0si and the DTC button doesn't do anything. I have done doughnuts in the rain and I can peel the tyres for as long as I want with no intervention of the DTC or DSC systems. No lights are on and there is no sign that something is wrong. Any ideas of what could be the problem?
I hope you guys can help me.
Thank you
Cc
      02-17-2015, 08:29 AM   #2
GeorgeT
GeorgeT's Avatar
Drives: 2007 750i; 2003 Z4 3.0
When you start your car, the DTC/DCS systems should be active; when you push the button it turns them off and wheel spin can occur (the DTC light will come on indicating the system is off). If you are having wheel spin without pressing the button there is something wrong.
      02-17-2015, 08:47 AM   #3
ccameselle
Drives: 2007 Z4 Si
Yes, the wheel can spin. there is no light at any point other than when I turn on the light. so yes there is something wrong. I am trying to find out what is wrong.
      02-19-2015, 08:03 AM   #4
ccameselle
Drives: 2007 Z4 Si
Any Ideas of what can be wrong?
      02-19-2015, 08:37 AM   #5
chickdr
Drives: 2006 M Roadster
Probably a dealer type issue. I would assume you need a code reader. When my DTC works it is obvious as the light flashes on my dash and you feel it working.
      02-19-2015, 10:47 AM   #6
Huz-Z
Huz-Z's Avatar
My 3.0SI is a 2006 automatic. With DTC in the default mode (i.e., operating), its just not possible to spin the tires appreciably, even if from a dead start with Sport mode engaged. So I agree that something is definitely wrong. Unfortunately I don't know what the issue is. But as ChickDr advises, get a code reader or head to a dealer.
Huz-Z
      02-20-2015, 08:49 AM   #7
ccameselle
Drives: 2007 Z4 Si
Does anyone knows what code reader I can get? I have an OBDII Bluetooth reader but I can't find a good software for the phone that will do more than just reading the codes. BTW. I have no codes showing in the computer. The car is clean.
