06-08-2011, 04:47 PM | #23 |
Rep 1,662
BMS used the magnaflow canisters.
Quote another one of Earl's posts. "Jose (fabricator/intaller) and Chris (BMS) designed it to be a 3-piece modular system, so customers will be able to order the cans, x-pipe, and scrubber cat-ellimination straight pipes separately. I thought this was a great idea since everyone's needs vary. Jose is sticking to Magnaflow parts whenever possible, because they are high quality and will be easy to source to replicate changes in-house. All the tubing is custom, and in fact Jose has been test-fitting and modifying the clearances and assembly process to ensure that each system will fit together perfectly, every time. The Magnaflow cans will have to be modified because of the angles of the BMW exhaust routing, so basically EVERY single piece in the system is modified in some way." http://www.bimmerfest.com/forums/sho...&postcount=223 2nd post by Earl. http://www.bimmerfest.com/forums/sho...&postcount=244
Current: '13 E92 M3 Euro Delivery Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3 |
