      11-17-2011, 08:24 PM   #1
3002 tii
3002 tii's Avatar
2288
New Kosei Wheels < 16lbs, How Strong?
Looking at a dedicated track setup and came across these, Kosei K4R in 17x8.5" at 15.6lbs. Anyone here also use Kosei wheels, if so can you comment on how strong they are?
http://www.tirerack.com/wheels/Wheel...t+Grey+Painted
Follow for latest mods
      12-03-2011, 08:25 AM   #2
Kim Schwartz
Drives: 128i
I have them and use them for my winter tires. I have had no problems at all. I have used Kosei K1 TS on another car as track set up and they were also just fine.
      12-04-2011, 07:58 AM   #3
schwank
Drives: 06 z4 m coupe
A lot of my fiends used Koesi Wheels on their e36 m3's and really like them (not these new ones...) none of my friends bent or cracked one. one nice this is they are cheap enough to not feel bad about replacing one.
K&W v3, APR splitter, magnaflow axle back35% tint, stubby antenna, Jet black, and interlagos blue stock wheels, clutch delay delete, illuminated ZHP shift knob, Leather Z m shift boot, and arm rest.
      12-23-2011, 07:55 AM   #4
guidance
Drives: M4, 335i
Hope they are stronger than the K1's.
Name:  Kosei crack 007.jpg
Name:  Kosei crack 002.jpg
      12-23-2011, 09:28 AM   #5
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
ouch. what size was that?
      12-23-2011, 01:46 PM   #6
3002 tii
3002 tii's Avatar
2288
I think I read the K1's don't have the necessary load rating for our cars and that's why they're not so great for street use (ie hold up against a pothole).
edit
http://www.e90post.com/forums/showthread.php?t=408291
      02-22-2012, 06:46 AM   #7
schwank
Im thinking about grabbing a set of these for the track (and to get there and back) anyone have any more info on them? any spacer advice? can i fit 255's up front (I have camber plates, and KW V3's)
      02-22-2012, 12:56 PM   #8
ZStig
279
you can fit 255s up front, you may have to use some spacers to move the wheel away from the strut tower though
      02-23-2012, 07:41 AM   #9
ANILE8
ANILE8's Avatar
No_Country
180
Drives: Z4 M Coupé - Carbon Black
You are probably better off in the long run using a fully forged wheel.
You end up getting what you pay for most of the time.
      02-23-2012, 08:12 AM   #10
prodigal_m
Member
prodigal_m's Avatar
Drives: 2018 Estoril Blue/Black F31
Not even remotely in the same price bracket. There's nothing wrong with cast or semi-forged wheels for track use...just don't be a retard with them.
