      07-09-2013, 05:33 PM   #45
Beedub
Originally Posted by seank View Post
And a rubber band?????????
Why wasn't the 550 kit available to us at only 1 psi more??????
no rubber band... just use a small sock!!
i have no idea to be honest........ im more than happy with the 8/8.5lbs i have to be truthful...... they mentioned to me the z4m fuel system couldnt support it....
      07-09-2013, 06:44 PM   #46
beta
Drives: 2006 M Roadster
Beedub, I was reading an article about the Z4 GTE and it reminded me of you. Notice the canisters at the top right of the picture and how they use socks to keep the fluids from spilling all over the place!
      07-10-2013, 02:01 AM   #47
Beedub
loooooooooooooooooooooooollll
      07-10-2013, 11:31 AM   #48
seank
enthusiast
seank's Avatar
48
Everythings custom CF and they have socks on parts. Crazy
      07-12-2013, 06:04 PM   #49
seank
enthusiast
seank's Avatar
48
http://i1122.photobucket.com/albums/...g?t=1373669952
Oil cooler shroud was made. It only dropped temperatures by 8 degrees, but it is working better than the free floating unit which caused high pressure in the the front as well as behind. Ducting behind would have been best, but there isn't enough space with the Setrab oil cooler that came with the unit.
      07-12-2013, 08:05 PM   #50
gmd2003
gmd2003's Avatar
352
Drives: 2014 CP M6 and 2006 VT 525 Z4M
Sweet ! Every little bit helps , I want one !!!
George
      07-12-2013, 09:33 PM   #51
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I'd say that its worth it for 8 degrees
      07-12-2013, 10:03 PM   #52
seank
enthusiast
seank's Avatar
48
I can probably get him to make some more if anyone needs one. He still has the template.
      07-12-2013, 10:23 PM   #53
gmd2003
gmd2003's Avatar
352
Absolutely , I'm interested , thanks ! PM me
George
      07-12-2013, 11:31 PM   #54
seank
enthusiast
seank's Avatar
48
I thought you would George. I will see how much it would be and contact you early in the week.
In the men time, I want to figure out why the boost reading isn't correct on the P3 Gauge:
Kinked line, not put in the correct hole, not calibrated correctly, or I have no boost.
      07-16-2013, 01:38 PM   #55
gmd2003
gmd2003's Avatar
352
Have you figured out the boost gauge?
      07-16-2013, 02:15 PM   #56
seank
enthusiast
seank's Avatar
48
No. It isn't working and i put out an email message and phone call message to Rick and havent heard back. He walked me through the parameters last week and said it would work, but it only reads -0.2 to 0.
      07-21-2013, 09:55 PM   #57
seank
enthusiast
seank's Avatar
48
He said they would be $200. You could also easiymake one if you have the time.
      07-21-2013, 09:56 PM   #58
seank
enthusiast
seank's Avatar
48
Boost gauge. Someone put the wrong sensor in the box.
      07-24-2013, 06:31 PM   #59
gmd2003
gmd2003's Avatar
352
Glad it was something simple. I'll let you know about the shroud but i will probably just fabricate my own. I've got a dyno session on Monday with full live engine diagnostics to sort out my persistent "yellow brake light" track limp mode issue. Wish me luck....
George
      07-24-2013, 07:21 PM   #60
seank
enthusiast
seank's Avatar
48
It makes sense. I used to have the time and no money and now I have the money and no time. So, I have him make it for me and fabricators make parts better than I could anyways.
I hope you get it worked out. Good Luck.
      07-25-2013, 12:42 PM   #61
seank
enthusiast
seank's Avatar
48
Are you using the P3 gauge?
I am only showing 6psi at full boost with the P3 gauge. Trying to figure out if others are showing a discrepancy with their calibrated gauge? Or if I should find out where there might be a leak?
      07-25-2013, 01:32 PM   #62
Beedub
im using the stack pro series........
i show just over 8 lbs at 7700 ish.... ( if its freezing cold... more)
AFRs show mid 11s at redline, WOT....
i emailed ess about th extra boost being produced and they some come out more, some come out less.... AFRs are good so ignore it....
      07-25-2013, 02:05 PM   #63
seank
enthusiast
seank's Avatar
48
6 and 8 are very different numbers and why would temperature make a difference?
      07-25-2013, 04:20 PM   #64
Beedub
im not sure.... afaik in very very cold conditions im talking sub 10 deg C BTW, air is more dense giving a higher boost reading... thats my understanding, i may be compltely wrong and happy to be corrected... however... i see slightly more in extremes of cold... and performance is incredible...
these are the pics i took of my peak recall and sent to ess.... these were running to around 7700 rpm... running to 7900 give a tiny but over 8....
this was a wiped peak recall making sure NOT to pop the limiter ( hence the 7700rpm) which gaves a spike and causes a very high reading....
oil pressure peak recall
      07-25-2013, 04:26 PM   #65
Beedub
if you want im happy to strap my iphone to the boost gauge and make a video for you.... ill try this weekend..... i've been seeing these boost numbers for years now....
im passing 6lbs relatively early in the rev range.... im guessing you have a boost leak.
the stack data-logger i have shows the boost figures are 110% accurate... again i can post this data if you wish.... just not sure how to do that bit...
      07-25-2013, 04:36 PM   #66
seank
enthusiast
seank's Avatar
48
I would like to see. It is not uncommon to receive the wrong parts from these kind of shops.
I received the wrong P3 boost sensor and I had to get another.
I have tightened everything up and installed better clamps on all the large pipes.
The difference in size between 2 pulleys is hardly noticeable (2-3mm). I just want to make sure that I am getting close psi numbers as I paid for.
So far, only 6psi with the P3 gauge and 2 psi has to be close to 50hp and 15 torque.
