05-04-2010, 11:21 AM | #23 |
BMW Fan
11
Rep 553
Knoxville
http://www.graysonbmw.com/index.htm?...OYK7wfijaldQ== I don't think you are comprehending what the others are telling you. On a unibody car, there is no "frame" per se other than a theoretical construct defined on a CAD machine as points in space requiring certain structural properties to which body and mechanical parts are attached. Your car has very significant "frame" damage in the front, probably extending to both sides. Because of the way the subframes are designed and interdependent on one another, it us unlikely that the damage is isolated to the one corner and probably the entire front half of the "frame" of the car is off. On the right side, the damage might be minor enough to be pulled back into place on a frame jig. On the left side, there is no way to pull back ripped metal and major structural repairs will be needed. In addition to major structural repairs, this entails having a detailed knowledge of all the mechanical systems so they can be disassembled and reassembled properly. Almost always, there is hidden damage which is not apparent until later or even after the repaired car is returned to the customer. For example, with an impact that severe, I would replace the entire left front suspension and wheel assembly no matter how they look superficially. This includes the strut, spring, upper spring mount, sway bar link, lower control arm, wheel carrier, wheel bearing, hub, wheel bolts, wheel, and tire. So you see it all adds up very quickly. Unless you can get that kind of repair done to your car, your are not going to get back the car you had before your accident. Last edited by AWM3; 05-04-2010 at 11:44 AM.. |
05-04-2010, 02:23 PM | #24 |
Rep 195
car62, I do understand what you are saying (better now) and appreciate it. Thanks for the link to the BMW shop. I have spoken to my insurance agent and they are looking into it. Waiting to hear back from them at this time.
05-04-2010, 02:27 PM | #25 |
Imola Lover
26
Rep 749
If they haven't torn down the entire front of the car (both fenders and everything north of the engine block removed), then they aren't ready yet to give you an estimate. Even then, it will probably take them a while as they'll need to get part numbers and prices from the dealership (due to the rarity of the car, they're not going to have the right part numbers in their system).
05-05-2010, 01:50 PM | #27 |
Rep 195
So my insurance agent informed me that because the curent collision center is a preferred service provider they don't require an adjuster. However, at my request they are going to go ahead and have an adjuster examine the damage to the car. Now the waiting begins again...
05-05-2010, 02:32 PM | #28 | |
Imola Lover
26
Rep 749
05-05-2010, 02:44 PM | #29 |
Rep 195
05-05-2010, 03:18 PM | #30 |
Rep 11,667
good idea.
05-05-2010, 10:09 PM | #33 | |
Rep 4,320
Drives: '07 Z4 M Coupe
05-05-2010, 11:04 PM | #34 |
Rep 304
I know at least with my insurance provider, they do not pay the shop if the finished total goes over their "total out mark". This keeps shops from doing an initial quote very low and then ringing up thousands of dollars of oops, we just found X is broken.
With that said, usually the repair shop will be very loose (over) with their quote than they expect the actual repair to be. All of this is kind of side info, but just FYI. |
05-05-2010, 11:08 PM | #35 |
Rep 4,320
I'd definitely get a second shops estimate on it.
$6k is WAY too low for that. My repairs are already at about $9/10k and the damage was much less.
05-06-2010, 10:00 AM | #36 |
Track Head
24
Rep 503
I agree, my car had cosmetic damage similar and was 4-5k to repair. This car has subframe damage that has compromised the suspension geometry (the fact the strut bar is bent and the shock tower is moved, is going to be quite fun to repair). You should be well over 15-20k to fix this properly.
05-07-2010, 07:22 AM | #37 |
Rep 195
Well met with the adjustor for my insurance company yesterday. The repair shop had pulled the frame back into place and had it on the jig for checking the alignment. surpirisingly looked better then I expected. No damage to the engine itself but some parts in the engine bay need to be replaced. The adjustors new estimate is above $10k, waiting for his final report. Additional elements to the the estimate included the front hood, driver side headlight unit, new tires and wheels on the front, and possible replacement parts for the front axle/springs, etc. But at this point there is not enough damage for them to be even be close to calling it a total loss. They said damage to the car has to exceed 70% of the current market value of the car for them to total it. I did make some enquiries and these guys are known for doing quality work in this area and for the BMW dealership, so i am going to leave it there to be fixed - and having talked with the guy working on the car, who has over 20 yrs of experience, I felt as reassured as I could. If anyone else has any additional information/advice it would be greatly appreciated. Thanks for all the comments and info so far.
05-07-2010, 07:24 AM | #38 |
Rep 195
Oh, I have the asked my insurance company to cash out the value of the front tires and wheels, so that I can use that towards a new set of wheels and tires. Thinking of forgestars at this point...
05-07-2010, 07:42 AM | #39 | |
Imola Lover
26
Rep 749
05-07-2010, 08:02 AM | #40 |
Rep 11,667
^ +1
I find that VERY surprising.
