      02-10-2008, 03:16 PM   #1
DocRiSK
DocRiSK's Avatar
Drives: Z4MC
It finally happened...
Well my tire pressure warning came on this morning while I was out for a short drive. I stopped and checked the tire pressures and my rear driver side pressure was down to about 28 PSI (Recommend: 39 PSI). Inspected the tire and found a nail in it. Looks like it occured some time in the past 2 days and has been a slow leak.
So I am contemplating getting it just fixed at a reputable tire place if possible. It is in the tread area and > 1" from the outer tread lines. I didn't run on them with no pressure or too low of a pressure so the side walls should still be in good condition and am hoping the tire is fixable. If not I'd have to dish out $330 for a new RFT tire!!!
I have heard the stock RFT's wear out < 20k miles. So this may be my chance to switch out all 4 tires for non RFT's. I have heard a lot about the Goodyear Eagle F1 GS-D3 and Michelin Pilot Sport PS2, but I found the Sumitomo HTR Z III on tirerack.com and they have a pretty good tirerack rating as well as user reviews (?? comparable to the F1 and PS2).
Plus the whole set of 4 would cost me < $600 . I lease my Z4 and figure I can just toss on the RFTs when my lease is up instead of potentially having to replace all 4 RFTs due to treadwear by the time my lease is up (4 x $330 = $1320).
http://www.tirerack.com/tires/tires....=(Y)&minLoad=S
Any one here have any personal experience with having had RFT's fixed?
Any one with any info regarding the Sumitomo HTR Z III tires?
Any other helpful comments would be appreciated.
TIA.
      02-10-2008, 04:19 PM   #2
vachss
Drives: Z4 Coupe
Had this exact same thing happen within the first 1200 miles I had my '07 coupe. Drove down to the local tire shop - Off, patched, on, 15 minutes and 20 bucks later I'm out the door and fine ever since. Unless you're near the point where you're going to replace the tire anyway just get it patched and forget about it.
      02-10-2008, 04:55 PM   #3
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
Had the same thing happen to me, driver side rear. Sidewall puncture so it was unrepairable. Picked up a set of Toyo T1R, have the other 3 Bridgestone RFT in my garage.
      02-10-2008, 04:56 PM   #4
Artz 330
Drives: Z4M, 335i, 135i
2006 330i  [0.00]
I used to patch all my RFT's on all my 3'ers
      02-10-2008, 05:29 PM   #5
DocRiSK
DocRiSK's Avatar
Drives: Z4MC
vachss and Artz,
how long can I expect the patch to last?
      02-10-2008, 06:02 PM   #6
Hawkeye
Hawkeye's Avatar
No_Country
2070
A patch will last as long as the tire lasts usually. They are not a 'temporary' fix as some thing.
      02-10-2008, 07:15 PM   #7
KevinC
your average JAMF
KevinC's Avatar
Trust me - get rid of the RFT's ***NOW***. It WILL be the best $$ you ever spend on your car, you'll be back here thanking me and raving about the improvements in handling, comfort, turn-in, and probably even a reduction in global warming and worldwide hunger. RFT's are the devil, anyone who's had them then come back from the dark side on the same car has the EXACT same experience.
I rented a turd of a Pontiac G6 while in SoCal the past few days. The multifunction display tells you exact PSI at each corner. If GM can put that in this rolling embarrassment, then why can't BMW give us that functionality, rather than just a cheesy idiot light that comes on after a huge amount of pressure is already gone? Riddle me that, Batman.
'21 M2 Comp
'19 Golf R
      02-10-2008, 09:28 PM   #8
judal98
Drives: 07 Z4 Coupe 3.0si
I just dumped the RFT's on my 07 Coupe...Kevin C's right, easily the best $$ I have spent on the car...went with Yoko S.drive, very, very happy, the improvement in ride quality is practically beyond measure, have heard great things about the Goodyear F1's, unfortunately the rear's were out of stock when I made the switch (apparently Goodyear ran out but has scheduled a production run soon)...good luck
      02-10-2008, 11:43 PM   #9
Hawkeye
Hawkeye's Avatar
No_Country
2070
As soon as the ice age passes I am getting some new wraps... But as long as it is -44 degrees with windchill and we get 13 inches of snow in 24 hours (last tuesday) there is no need.
Come on summer!
      02-11-2008, 12:15 AM   #10
BimmerZealot
Some troll @ Firestone tried to tell me my Toyo's are junk and the OE 18's will perform better with the Bridgestone RFTs. Then proceeded to say I was fortunate to find a company that would do the dangerous act of putting the Toyos on my rims.
      02-11-2008, 05:03 AM   #11
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
RFTs are dumb.
You have to be 100% behind someone before you can stab them in the back.
David Brent
      02-11-2008, 07:07 AM   #12
BlackSapphireZ
Drives: 22 GLE 53 Coupe
Come on summer!
you need to move lol i'm complaining cuz it's 10degrees here in Maryland(where i'm at) at this moment. HIgh is 30 with windchill of 0. this is an iceage for us haha
you CAN patch run flats just like regular tires
if you don't need to spend money on tires yet, just keep em till it wears out. why spend $1000 when u got a perfectly good tire? Stock RFT RE050A's are sticky enough. but when it comes to getting a new tire, of course the non-RFT's
2022 GLE 53 Coupe
      02-11-2008, 08:44 AM   #13
MiniMayor
MiniMayor's Avatar
Drives: 2010 135 coupe
Should have bought tire insurance.
      02-11-2008, 09:52 AM   #14
wrh3
Car Guy
wrh3's Avatar
31
Drives: 2005 MCS, 2013 Corvette 427
Originally Posted by BimmerZealot View Post
Some troll @ Firestone tried to tell me my Toyo's are junk ......
That's funny, I think they have one of the lowest return rates out there
But I guess this is coming from a Firestone employee
Bill- 2005 Mini Cooper S, 2013 Corvette 427
www.billswebspace.com/bmwindex BMW CCA Member # 389948
      02-11-2008, 04:00 PM   #15
DocRiSK
DocRiSK's Avatar
Drives: Z4MC
Well took the car in today during my lunch break (it's one of the authorized installer's for Tire Rack and very reputable place with good customer satisfaction around here). They took close to an hour but they patched it. They said they had to take a litte extra time and caution it being a low profile tire... anyway an hour later and only $21 less I was ready to go. I am still planning to switch over to non-rft's and will give the Sumitomo HTR Z III a try, but will wait until I put a little more wear on the RFT's first.
Thanks to all for your input.
      02-11-2008, 04:58 PM   #16
pbdm4k
pbdm4k's Avatar
Drives: 2010 335d
Sumitomo = made in china crap.
GoodYear F1 from personal experience are horrible in the rain. No wet grip whatsoever.
I'd take the Michelins over the Goodyears.
Personal favourite right now is the Nitto Invo.
2006 VW Jetta 2.5
Once upon a time...
'03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T
