05-20-2009, 11:08 PM | #1 |
Rep 969
TPMS Question
Hey guys -
As per my other thread you might tell I am in the market for some new/different wheels. My car is an 07 M coupe with prem package. 1) Can I install the stock TPMS into different aftermarket wheels without un-mounting the tires on my stock wheels? Is this possible and/or difficult to do? 2) Is there any harm or concern if I install aftermarket wheels without any TPMS sensors and just run the car in this manner? Will the ECU freak out? Thanks in advance! |
05-20-2009, 11:17 PM | #2 |
Rep 291
YES YES
You need the sensors. I had mine pulled out of my factory wheels without removing tires and instaled in my new wheels. Make sure news wheels are TPS friendly
05-20-2009, 11:44 PM | #3 |
Rep 969
Awesome! Thanks for the quick response.
DIY on how to remove the TPS sensor or is it straight forward? I'd rather no have to mount and remount tires each time I change tires. Unless TPS sensors are relatively cheap to just buy. The wheels are Fikse Profil 10s - is there a a spec I can check to make sure they will fit? Thanks again! |
05-20-2009, 11:48 PM | #4 | |
Rep 969
05-27-2009, 06:16 PM | #5 | |
Rep 969
Anyway, I went for a drive around the block, the tire pressure idiot light flashed and then went solid, but the car drove completely like normal. |
05-27-2009, 09:15 PM | #6 |
Rep 962
yeah you don't need the tpms. I don't have them in on my car right now. I have a light because i don't have the tpms, but i just took electrical tape and put it over the light on the glass.
05-28-2009, 09:34 AM | #7 |
Rep 12,565
i dont have tpms on my winter setup, dash icon just stays lit whole time, not a big deal.
