      05-25-2010, 09:28 AM   #1
Matty C
Matty C's Avatar
Germany
20
Drives: 2007 Z4 M Roadster, 2006 M3
Looking for DIY installing aftermarket headers?
If anyone has seen a post or has documented doing this mod I would appreciate your reply.
2007 Black Sapphire Z4 //M Roadster, Hamann Front End, Hamann Rear Diffuser, Hamann 19 Inch Anniversary Wheels, Eisenmann Race Exhaust, Group M Intake, RPI Ram Air, CDV Delete
2006 E46 M3, 2004 Jeep Rubicon, 93 Golf VR6
      05-25-2010, 09:40 AM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
you may find something on the e46 M3 forums.
That's probably the closest you'll get.
      05-25-2010, 10:30 AM   #3
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
I really should have done a DIY but I was fighting time. I had to do it outdoors with 12 hours of good light and a flashlight. Let me look for some links. I am also here if you have any specifics. I have some tips and such like tools needed, things like that.
http://www.bimmerfest.com/forums/sho...d.php?t=419474
http://karcraze.com/headerdiy.htm
Here's another good writeup above.
I only had to remove one 02 sensor from the car because it was hard to get off with the header installed. MARK YOUR 02 SENSORS..Important. If you have an o2 sensor socket you can get three 0f the four off the headers before taking out of car. This way you only have to worry bout having to reattach one 02 wire to the cylinder head cover. Use PB blaster on the header nuts and let soak for a while.This will help keep your nuts from coming out with your studs. I would get new studs along with nuts just in case this happens. I did not have the studs and it sucked as I had to rethread a couple. They are cheap. This caused me to have to actually remove the headers once partially installed. Not fun.
A great mod. I love it.
Take your time and ask questions before you get into the install.
      06-04-2010, 11:29 PM   #4
cloud8r
Member BMW CCA Los Angeles
cloud8r's Avatar
Drives: 2022 M8 GC Comp
2018 BMW M4  [0.00]
Would u happen to have the part number for the studs? I could only find the pn for the nuts
Current Rides:
2022 ///M8 GC Comp
Much enjoyed:
2018 ///M4 ZCP || 2014 ///M5 ZCP || 2011.5 ///M3 Sedan || 2007 ///M Coupe || 2008 550i Sport || 2006 ///M3 ZCP || 2008 X3 3.0si || 2006 325i || 2003 Z4 3.0 Roadster || 2003 330ci || 2002 325i
      06-07-2010, 09:43 AM   #5
mousitch
Dark Sider
mousitch's Avatar
129
08 Stud bolt M7X30 18EA PART # 0712990029
Dont forget gaskets either.
