      08-26-2013, 03:05 PM   #1
Shipkiller
Shipkiller's Avatar
Drives: Me
Rear Spring Perch
I am finally going to put new springs on my car.
Knowing that installing the HR springs, the rear is going to sit a little lower than the front. After reading most of the threads here in this section, some of you are using up to a 15mm spring pad in the rear to compensate.
I have searched for a E46 spring pads but I have only found rear spring pads for the E36. My search parameters may be wrong. What rear spring pad are some of you using? Where did you purchase them from?
Trying to get this all accomplished before Sept 19th.
edit: I think I answered my own question.
      08-26-2013, 04:36 PM   #2
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
http://www.turnermotorsport.com/p-42...pair-15mm.aspx
2006 Z4MC - #LL93158
      08-26-2013, 04:52 PM   #3
Shipkiller
Shipkiller's Avatar
Drives: Me
Thanks.
I modified my search parameters and found them...
      08-26-2013, 06:58 PM   #4
Shipkiller
Shipkiller's Avatar
Drives: Me
Caddy,
To make sure I do not do anything stupid, these spring pads go ON TOP, not on the bottom?
      08-26-2013, 07:43 PM   #5
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
IIRC it didn't matter, I think they were on top.
      08-26-2013, 07:44 PM   #6
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
BTW; I don't think anything you do is stupid...
      08-26-2013, 08:26 PM   #7
Drives: M2 Comp
This^
      08-26-2013, 08:28 PM   #8
Drives: M2 Comp
IDK......
I remember certain a pirate that will go unnamed..........
      08-26-2013, 10:46 PM   #9
seank
enthusiast
seank's Avatar
48
Why not buy a longer spring or adjust the coil overs. Ignore me if the h&r's don't allow this.
      08-27-2013, 04:51 AM   #10
Shipkiller
Shipkiller's Avatar
Drives: Me
A good question, but it does not apply to me. I am not running coil overs. At this point in time, I do not want to do coil overs yet.
I am running Bilstein HD's. The only reason I never changed the springs before, was I did not want to run the dampers at the edge or outside of their designed working zone, or be running on the bumpstops, and I really wanted more spring rate. I found out that Bilstein Sports and HD's are designed to work with non-OEM springs (up to a point...) without said drawbacks. This information came directly out of the mouth of a Bilstein Engineer.
Plus, I do not throw parts at the car.........
      07-25-2014, 10:05 PM   #11
RedDotRacer
Drives: 07 Z4mc
Bumping this for later
