      08-25-2012, 05:27 PM   #23
arobyte
Drives: 2006 BMW Z4 M Roadster
Problem Fixed
Yes it was coils. 3 of 6 coils were bad. Replaced and car drives amazing again.
Thanks all for your input.
      08-25-2012, 06:18 PM   #24
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
Looking back do you think it was smart to rev an engine running on 3 cylinders?
      08-25-2012, 06:43 PM   #25
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Interesting that 3 would go at the same time?
2006 Z4MC - #LL93158
      08-26-2012, 09:25 AM   #26
arobyte
Since it helped in quickly diagnosing the issue with the fine people on this board, no regrets.
So the next guy doesn't need to rev his engine to figure it out.
      08-26-2012, 04:32 PM   #27
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
I would have replaced all 6 of those things, seems it should be routine maintenance ~ 30k LOL
      08-26-2012, 06:42 PM   #28
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Thinking the same. Hell; I replaced the plugs at 21,000 miles just because it was apart for Inspection I.
      08-26-2012, 09:15 PM   #29
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Yup, did the same with the plugs at 24k. Short of going with plasma coils *($$$$)* , just have to keep some on hand.
      08-27-2012, 05:08 PM   #30
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
What is the maintenance interval/mileage for plug replacement for M's (no track time)? I think I'm going to replace all my coils soon and would do the plugs as well if it makes sense.
      08-28-2012, 12:32 AM   #31
StickMon
StickMon's Avatar
Drives: 2006 MR
I think inspection 2, which would be nominally 60k.
I've chosen to replace them on each valve adjustment, nominally 30k.
They have crush washer seals, not tapered seats, so you probably shouldn't take them out and then put them back.
      08-28-2012, 09:21 AM   #32
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
I believe this as well, if I'm pulling them, I'm replacing them. The good news is that the NGK and Denso iridium plugs are cheaper than the OEM two-prong plugs,and they can be gapped (carefully).
