      03-09-2012, 01:41 PM   #1
baege
Drives: 2022 Cayman GTS 4.0 6MT
Tire pressure for 3.0Si coupe with non-run flats
With the rise in temperatures, looking to ensure my tire pressure is in the correct range.
Did some searches and can't seem to find a definitive answer on what the tire pressure should be for a 3.0si coupe running the stock sizes 225/40 up front and 255/35 back with non-run flat tires (Pilot A/s +1 in my case)
Some say go stock 32-33 front, 37-38 rear
some say go 32-33 all around
I've been running 32-33 front 37-38 rear but I do find my ride a bit bumpy?
views?
      03-09-2012, 02:50 PM   #2
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
if your car is loaded with the optional sport package (zsp), then "bumpy" is what you'll be living with regardless of pressure. especially if you're on 18's or more.
i ran with 32 on all four corners with non-RFTs and 18's, but it was still pretty harsh. still... it was MUCH less harsh after ridding myself of the RFTs.
      03-09-2012, 04:02 PM   #3
Shipkiller
Shipkiller's Avatar
Drives: Me
What does the sticker say?
      03-12-2012, 09:54 AM   #4
Hawkeye
Hawkeye's Avatar
No_Country
2070
There is a sticker in the drivers side door frame that should tell you. I believe it says low 30's.
      03-12-2012, 10:54 AM   #5
Huz-Z
Huz-Z's Avatar
Ditto!
Huz-Z
      03-12-2012, 12:01 PM   #6
baege
Originally Posted by Huz-Z View Post
Ditto!
The sticker is for the factory provided run flats
33 front 39 rear
There are opinions that those PSI values only pertain to run flats and so when you switch to non run flats the issue is open to debate
      03-12-2012, 12:46 PM   #7
ruscoupe
ruscoupe's Avatar
Drives: 2007 z4 3.0si Coupe
The answer I've seen offered to the question most often, which I happen to agree with, is that there isn't a one size fits all answer. Too many variables, and they go beyond RFT vs non-RFT. One important consideration for example would be roads typically driven, particularly if the car is used as a daily driver.
Sure, there's a min/max recommended range for PSI, and that's usually what you're going to find on the door jamb unless you're running a completely different setup (in terms of size) than OEM, but other considerations vary depending on such things as tire brand, average ambient temperature (i.e., not the same for a car in Maine as it would be a car in Arizona), etc.
Rus
      03-13-2012, 09:21 AM   #8
imz4n
imz4n's Avatar
Drives: 2006 3,0 si TITANIUM SIlVER
I run Hankooks on my Si. For freeway driving 34 front and 40 rear. for tracking purposes I reverse that 40 front and 34 rear. I also had a alignment done and took out 1 deg of camber in the rear and added 2 deg of toe in in the front. This is from stock settings.
SoCal Z Enthusiast contact me to get on the list. Events for like minded people and when you talk about your Z, we will know what you are saying. https://www.facebook.com/groups/ZSCCACalifornia/
      03-13-2012, 09:45 AM   #9
v3.2mc
Not a New Member
v3.2mc's Avatar
Originally Posted by imz4n View Post
... added 2 deg of toe in in the front.
you did this on purpose?!
i've not heard of doing this before... what are the advantages?
      03-13-2012, 10:16 AM   #10
imz4n
imz4n's Avatar
Seeing how I have less track time than normal driving.
The toe keeps the car from being twitchy ( wondering in the lanes going down the freeway ) not trambling issue. Side advantage it helps with turn in. Needless to say I do not have flat edges on the outside of the front tires. The front tires do not wear out on the outside edges. Not too much toe in to cause issues.
      03-13-2012, 11:18 AM   #11
Shipkiller
Shipkiller's Avatar
Drives: Me
TWO, TWO degrees of toe???? That will wear out a tire faster than anything else.
Plus, I cannot understand how that much toe would give you better turn-in. I have my toe set to zero, and that was a great improvement in turn-in feel.
Bob, are you pulling a fast one here??? I would not put it past you...
      03-13-2012, 11:24 AM   #12
Hawkeye
Hawkeye's Avatar
No_Country
2070
33 front 39 rear
You can debate all you want, but the sticker in the door is not just for runflats. It works perfectly fine with my non-rft, and if you had ever ran runflats you would not think your ride was bumpy in comparison.
You asked for an opinion and I gave you mine.
      03-14-2012, 08:35 AM   #13
damikmak
Drives: 2007 Z4 3.0si Coupe
Hawkeye has it right about the door sticker. 33 front and 39 rear. Works perfect on my 19 inch wheels with non runflats
      03-16-2012, 02:41 PM   #14
sbtwister
sbtwister's Avatar
Drives: 2005 3.0i Z4 Roadster
I've got Michelin Pilot SuperSports, same size on 18" wheels, with M-Sport suspension. I asked the tire installer about proper pressure, they set it up as 36 psi - rear, 33 psi - front.
The rear does feel a little firm - but... it's a sports car.
Alpine white Z4 3.0i, Dream red leather, M-sport seats, Sport package, Xenons, Heated seats, Premium sound, XM Radio, Aux in, Strut brace, Black grill, CF Roundels, Stubby, Half foam.
      03-17-2012, 10:59 AM   #15
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Wow...you guys are running on pretty high pressure for daily uses. My door jamb says 30F and 30R and I normally just run at 32F/R.
      03-18-2012, 01:00 PM   #16
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
I normally run 32F/30R for everyday use with summer or winter tyres. To get the right amount of sidewall flex with 245/40-18 front and 275/35-18 rear Dunlop Star Specs, I typically use 38F/34R for autocross and 36F/34R for trackdays.
      03-18-2012, 09:45 PM   #17
santov
santov's Avatar
64
Drives: 2007 Z4 3.0si White over Beige
I think the door jamb sticker only applies to the OEM tires. I also don't think that +/- a few PSI is going to make a huge difference im ride.
Personally I ride at 75-80% max pressure printed on the side of the tire. I check constantly that the center of the tire isn't wearing more than the outter edges. I adjust the pressure accordingly. My hope is to get max MPG and max wear, both of which are supported by higher pressure, just so long as they wear evenly.
