      08-20-2019, 01:08 PM   #1
pegasusactual
Drives: 2003 BMW Z4
E85 Z4 airbag light code 9485
My 03 Z4 seems to activate the airbag warning light after a hard bump or other randomness and reports error 9485 "clamp r signal inconsistent". I think it's a wiring issue. It would not surprise me if some wires in the driver's side loom have fatigued for instance.
"Klemme R signal inkonsistent" is the German INPA description.
Can anyone shed some light on this?
Thanks!
      08-21-2019, 11:45 AM   #2
Clearancediver
Drives: 2004 Z4
Remove and clean battery clamps.... going on "senior memory" here but believe "clamp r" is battery connection/power issue.
Airbag light will illuminate to indicate increased resistance/low voltage on SRS power connection... which is directly connected to positive battery clamp. Which seems consistent with your issue.
My 2 cents....
Sent from my smart phone...
Tags
9485, airbag, error
