      05-10-2013, 03:27 PM   #67
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Ok, to settle this, we need an 18 wheeler flat bed that can accelerate at the same rate as a Z4M with a dyno on the back. Let make it happen zpost!
      05-10-2013, 04:11 PM   #68
exdos
England
Drives: Z3 M Coupe(S54) and Z4 M Coupe
That's a cracking idea and not as daft as it seems. I have seen the video of a similar thing used for testing a tethered microlight aircraft.
Alternatively, why doesn't O-cha put his Z4M on a static dyno using his Autoenginuity software to datlog the ECU at the same time as the dyno runs to prove me wrong and show us all what really happens?
      05-10-2013, 04:42 PM   #69
David70
This conversation reminds me of this video on many levels.
Note the industrial fan at 2:20.
      05-10-2013, 06:16 PM   #70
StickMon
StickMon's Avatar
Drives: 2006 MR
Heading to Lowes to pick up a couple of leaf blowers.
Will post results.
      05-10-2013, 09:51 PM   #71
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
Here is the proper way to do electric forced induction: http://www.autocar.co.uk/car-news/mo...ger-technology
      05-10-2013, 11:56 PM   #72
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
The video was exactly what I was thinking when reading Exdos's posts. Because it seems to me that his general explanation of how he's getting such crazy power figures is due to the fact that a lot of air is being fed into the intake manifold...
And I've already noted in another thread that unless the air is pressurized, there's only so much air that an otherwise stock engine can make use of
      05-11-2013, 05:02 AM   #73
exdos
England
Let me make a few essential points for you so you might understand this better.
To increase Torque you need to increase engine Volumetric Efficiency. Since the engine capacity is a fixed volume, the only way to increase the VE (i.e. the mass of the air/fuel charge in the cylinder) is to increase the pressure of air entering the cylinders and/or have the temperature of the charge as low as possible.
Horsepower is calculated from Torque x RPM/ 5252. Because in that calculation the RPM is divided by the constant 5252, the point in the engine rev range at which Peak Torque occurs has a very significant effect on the HP figure which is calculated. I didn't make up that formula, so don't shoot the messenger! Try a few different calculations yourself to see how this works.
At 8000rpm the S54 engine consumes (3.246litres x 4000 =12,984 litres) = 12.984 cubic metres of air/fuel mix. Air at 20 °C and 101.325 kPa, dry air has a density of 1.2041 kg/m3, therefore, if the S54 engine at 8000rpm can be filled with air at this density, then it will consume (12.984 x 1.2041 =) 15.6340344kg/min of air (34.47lbs/min). If the air density is different, then the mass of A/F mix will be different, but the volume of 12.984 cubic metres of air will always be the same.
A vehicle travelling through air will experience an equal and opposite force from the air related to the speed at which the vehicle and the air are travelling relative to each other which will create ""ram pressure". As such, an air intake designed to capture and retain air at ram pressure can supply an engine with air at a pressure greater than ambient pressure, therefore, it is possible to achieve a greater VE than would otherwise occur if the source of air is at ambient pressure, only. The Z4M's OEM air intake is such a design.
I've previously stated that the OEM Z4M will record around 31lbs/min as Airflow through the MAF at 8000rpm in 3rd gear and since the charge at WOT is an A/F mix at around 13:1 AFR, then the actual charge is 31lbs of Air + 2.38lbs of Fuel = 33.38 lbs of A/F mix. Therefore the OEM S54 engine is operating at a VE of 96.85% at peak revs.
Since the engine is an air pump, the exhaust system must also be made more free-flowing so that exhaust gases can escape to allow the greatest cylinder filling (i.e. highest VE/torque). The Z4M's OEM ram air-intake is very good, but it can be improved by using the same scientific principles long used in other totally unrelated applications. The objective is to provide the engine with a constant supply of air at ram pressure and the graph below shows how ram pressure increases in relation to speed. Therefore, the faster the car travels the greater the pressure difference above ambient pressure is the charge, thus increasing VE/torque and shifting the peak torque to higher rpms, thus considerably increasing the HP.
      05-11-2013, 06:37 AM   #74
johanness
Drives: 2008 Z4MC
      05-11-2013, 07:52 AM   #75
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
If what you say is true, then at 100% VE you will gain another 3.15% over stock.
If the S54 produces at 180 ft*lbs torque at the rear wheels at 8000 rpm (274.2 whp), even at 100% VE you would only produce 8.6 more hp (282.8 hp).
To produce 370 whp, you will need to run the engine at 131% VE, or increase cylinder pressure by about 4.5 psi on a standard day. 4.5 psi is the same pressure increase that a Vortech blower gets by spinning at tens of thousands of rpm. That's a whole lot of air.
http://en.wikipedia.org/wiki/Ram-air_intake
At low speeds (subsonic speeds) increases in static pressure are however limited to a few percent.
Anyway, sorry to be OT.
      05-11-2013, 09:57 AM   #76
zubydafa
tosser
Isle of Man
31
Drives: '07 Z4MC
not sure if srs
'07 MCoupe
lots of mods
      05-11-2013, 10:32 AM   #77
exdos
England
The Volumetric Efficiency of an engine is constantly varying and is not a fixed percentage. The published VE of the OEM S54 engine is 106% and this will occur at, or close to, peak torque, which is normally at 4,900rpm and therefore peak torque is the place to best look rather than max revs. Normally, the lowest Intake Air temperature recorded by the OEM air-intake is 7degrees C above ambient temperature, but I've now I've got mine working at ambient temperature without relocating the MAF/IAT sensor. Obviously, this increases the density of the charge.
Likewise, in OEM format at 4900rpm at WOT in 3rd gear acceleration, the MAF of my Z4MC shows an air-flow rate of around 21.38lbs/min but now, after gutting the silencers and doing a few mods to the air intake system, the airflow rate is now in the order of 23.07lbs/min, in similar ambient conditions. That's an increase of 7.49% in the mass of air ingested so the VE has increased to 113.93% at 4900rpm. Because I've made the air intake more able to harness the ram effect at all speeds, the increase in ram pressure with the increase in speed means that there is less pressure drop within the air-intake system as engine rpms increase, and consequently, the plot of torque now shows less of a peak and more of a plateau across the upper range of rpms, where my MAF now records an airflow of over 34lbs/min in comparison with the OEM figure of 31lbs/min, an increase of 10.3%. When I use a Magnehelic Differential Pressure gauge to monitor the pressure within the air-intake system, in 3rd gear acceleration at WOT, now, the pressure never dips below ambient pressure. I have produced the acceleration figures for all to see, elsewhere.
Nobody seems to bother much about the gains in torque, and all the critical focus seems to be on HP. The formula to calculate HP shows quite clearly why the shift in peak torque as far up the rev scale as possible gives such huge increases in HP. I don't make up the figures I record and I didn't make up any of the formulae to work any of this stuff out.
Anyway, here's a graph showing the torque/hp of my car in OEM format, with gutted silencers and modified intake. It seems that the spike at the end of the torque curve in the yellow plot that is causing all the trouble.
      05-11-2013, 10:32 AM   #78
DanFromTucson
Drives: Z4 M Coupe
Can we get this thread back on track? Let's help this guy out and develop some useful information for others with this tune.
      05-11-2013, 10:58 AM   #79
exdos
England
Certainly. The dip seen in the OP's dyno plots at around 7300rpm is also markedly shown in one of my plots from "real world" driving as above. So I guess this is normal for the Z4M.
      05-11-2013, 01:56 PM   #80
mfanatic325
///M-fanatic
Taiwan
193
Originally Posted by johanness View Post
Originally Posted by zubydafa View Post
not sure if srs
I think only Evolve can help these fine folks out right now...
Just ignore Exdos. Anyone that's silly enough to believe a figure of 370rwhp with intake modifications on an otherwise stock car clearly has zero common sense. Again, as others have stated in other threads: not to take away from the work that he's put into logging data, but come on....enough is enough
If it were THAT easy to produce power, why don't you copyright or trademark your amazing intake invention and make thousands off of Z4 owners the world over? I double dog dare you
Oh, and I'd like to ask for a measly 1% of the share of the profits, since I just provided you this wonderful monetizing idea. Heck, I even have a patent lawyer that I can hook you up with
      05-11-2013, 05:42 PM   #81
exdos
England
That's precisely what I've been researching. If I ever attempt to market the invention it will be independently tested by a recognised engineering faculty rather than some bloke at a dyno shop with an inadequate fan.
      05-12-2013, 02:40 AM   #82
johanness
Drives: 2008 Z4MC
OP should contact a different tuning company that knows what they're doing, or keep waiting for Evolve to get it right & listen to their excuses in the meantime.
There's no forum-member cure here.
      05-12-2013, 08:50 AM   #83
kennyfrc
kennyfrc's Avatar
18
Drives: 2008 Z4MC
Has anyone dyno tested the tune from ESS?
Looking at stock AFR which are rich in upper RPM it would seem power could be gained from correcting them. My car broke 300WHP on a stock tune, I am going to need some SOLID proof something actually works to warrant the cost.
Daily: 2010 Tacoma Double Cab
      05-15-2013, 07:42 PM   #84
Spreadsheet
Drives: Black 2007 Z4MC
I am running an ESS tune installed in 2009, only mods to my intake/engine/exhaust so far is RPI scoop, K&N, ESS tune and BMS mufflers. I am getting ready to install SS stepped headers and cats, also purchased Evolve-R software and wanted to get a baseline dyno run. As you can see, initial run to 5,500 rpm looks good with Torque at 235 pound-feet, which equates to about 276 once you figure 15% loss, so good there. Then HP falls off the map and looks like the dyno ajw45 has. Dyno tech suspected may be knocking on 91 gas here, but AFR leaned out a bunch after 6K. My plan is to run some racing gas with the ESS tune and re-dyno this Friday. If I get the same result, then will have the dealer flash back to stock, then re-dyno. I need to find out why ESS giving me the harsh top end when the hp and torque to 5.5K looks so good. I need to resolve before installing headers/cats and Evolve-R software. Not sure what happened on the third run in 3rd gear, looks like something slipped at about 6K and recovered. First two runs so similar.
Any ideas anyone?
