      02-03-2016, 02:01 PM   #45
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
They don't have them listed on their site for z4s , do either of you know if they still produce them?
      02-03-2016, 03:21 PM   #46
Beedub
think I'm one of the minority thats very happy with the stock change, hell even the stock gear lever , lmao!
      02-03-2016, 03:57 PM   #47
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
They did a GB run for us.
If you contact them, I'm sure they will do a one off. (not cheap though)
Its been long enough, maybe there's interest in another GB here.
      02-06-2016, 05:36 PM   #48
dfjaws
dfjaws's Avatar
Drives: E90 M3 / E86 M Coupe
I would be interested.
      02-09-2016, 02:08 AM   #49
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
i would be interested too!
      02-09-2016, 04:07 AM   #50
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
You'd see some improvement with a short shift kit mate. I think it's worth it.
      02-09-2016, 04:55 AM   #51
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Right now I'm tossed up between the RE kit or this. RE kit is immediately available and not as pricey, however I do not doubt the AS ssk would be a better choice
      02-09-2016, 06:34 AM   #52
3002 tii
3002 tii's Avatar
2285
Get the AS, trust me lol
Although if you go AS its so notchy you'll need to change to a taller knob
Follow for latest mods
      02-09-2016, 07:29 AM   #53
Beedub
exactly my problem with SSKs they make the shift either heavier or add alot of notchyness to the shift quality...
      02-09-2016, 03:20 PM   #54
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
I love my AS SSK paired with the M5 knob!
      02-09-2016, 03:26 PM   #55
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
I put the stock knob back on after the install. Works for me.
2006 Z4MC - #LL93158
      02-10-2016, 12:43 PM   #56
DanFromTucson
Drives: Z4 M Coupe
Does anybody still have one they need to install? I installed mine ~6 months ago (with help from this thread) and thought about adding my installation tips. I figured I may have been the last one to install the shifter from the final group buy though.
      02-10-2016, 12:56 PM   #57
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^ I know someone who has yet to install.
I think he was planning to get to it this spring.
      04-24-2016, 10:22 PM   #58
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
Unless he has made any changes to how he is manufacturing these, there are a few tiny little mods/tricks you can make to the AS kit during installation that will take ALL notchiness out of it. As I recall I discussed what I did in my original posts but honestly, I haven't read through it again (I'm really friggin long winded!....) Mine ended up not notchiness at all and also took out all the slop of the original, which I am very familiar with having had an E46 M3 before this. If you think you are happy with the original that is great but truly, you really can't imagine just how much better it can be.
      04-12-2017, 07:53 PM   #59
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Great write up, will be going through this on the weekend. I have to remove my diff anyway, so I'm thinking I might as well remove the driveshaft to hopefully make things a bit easier. That clip doesn't sound fun
For anybody curious, Ronald is still making these. Got mine within a week of ordering, custom spec, and around GB price ($350 + shipping?)
      04-13-2017, 10:32 AM   #60
DanFromTucson
Drives: Z4 M Coupe
More tips:
1. Take a curved pick tool and use it to hook over the old clip & yank it out. I can't remember if I read this somewhere or thought of it myself, but it made the process much easier.
2. Assemble the AS shifter outside of the car and rotate the bushings a few times. The tolerances are so tight that it can be hard to install the first few times. If you slip it on & off a few times outside of the car, it's much easier to do the final install.
      04-13-2017, 10:48 AM   #61
Sliktop
Drives: 07 Z4 M Coupe
Sounds like a few of you have AS kits on order, I talked to Ronald this morning about a kit for my Z4MC, might have to pull the trigger on this soon...
      04-18-2017, 06:47 PM   #62
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Went through this earlier today. Thanks again for the guide. Check out the room you get when the drive shaft is removed that round clip is no sweat when you have space
      04-19-2017, 03:06 PM   #63
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
FWIW...
anyone removing the drive shaft should inspect & replace the guibo at the same time.
If you have a few miles on the clock... just replace.
Also, check the rear CV joint, it should be repacked. (use CV grease)
When repacking its a good idea to fill the flange on the front of the diff. with grease,
it helps keep the grease in the CV joint.
yousefnjr6157.50
      04-19-2017, 04:46 PM   #64
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
FWIW...
Yep, mine was cracked, 72k miles there's also a pink seal on the CV end that should be replaced, was only $5 at the dealer
Guibo - 26112226527
Driveshaft CV Gasket - 26111229503
inTgr8r2431.50
      07-09-2017, 07:27 PM   #65
nutzkicker617
nutzkicker617's Avatar
28
Drives: Z4 M Coupe
Will be tackling this install soon.
Pictures are no longer showing up...any chance these are still around?
Thanks!
      07-12-2017, 02:08 PM   #66
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
Whew, major thread revival. I'll have to see if I can locate the photos. It's been a loooong time since I posted this, or since I've been around here. The addition of kids, a boat restoration project, one thing after another and I haven't focused on the car much. Shoot, it's embarrasing as hell, car only got 500 miles on it last year.....but it seems the low mileage versions are a bit of an appreciating or at least status quo investment. I'll look into the photos, redo what I can.
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
