      01-14-2016, 05:53 PM   #1
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
What company makes section 1 and 2 a 1 full pipe?
Hi,
I was wondering if there is a company that makes section 1 and 2 a long full straight pipe instead of 2 separate pipes?
Was trying to find on google, but whenever I put pipe midpipe exhaust etc it only shows RE and supersprint.
Thank you
      01-15-2016, 01:12 AM   #2
Beedub
2 separate pipes is the same as having one larger bore pipe.... either or works nicely.
      01-15-2016, 09:54 AM   #3
Drives: M2 Comp
Not a lot of choices for section 1.
DKF is the only other one and they have the S pipes welded together with tabs and separate CAT/resonator piece.
      01-17-2016, 12:25 PM   #4
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
For what car?
      01-17-2016, 12:45 PM   #5
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Originally Posted by TheAxiom
For what car?
Z4m
Instagram: ariusen26
Youtube: Track vids
      01-17-2016, 05:23 PM   #6
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Z4M Midpipe:
http://www.rogueengineering.com/rogue/MZ4EX/MZ4CP.html
Z4M Xpipe:
http://www.rogueengineering.com/rogu.../E85MZ4XP.html
Racerbruce
      01-17-2016, 06:44 PM   #7
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
Do not buy their midpipe; horrible fitment.
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      01-17-2016, 07:21 PM   #8
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
I think part of the reason it hangs lower is because their transmission mount bolts are longer, causing clearance issues.
      01-17-2016, 11:57 PM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
The stock midpipes go past the trans mount before heading for the center.
All of the aftermarket pipes sweep in toward the tunnel too soon off the headers.
That makes them go across the bottom of trans mount.
Some more than others. There's a tread here somewhere with pictures. May have been Rated M's thread.
I have the RE's and had to twist them to clear the trans mount. One of them hangs down quite a bit.
IIRC, Rated M had to do some fiddling with the RE X-pipe as well, to get it to not rest against anything.
      02-02-2016, 02:07 PM   #10
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
Haven't been around here in a loooong time. Thinking about installing the euro headers I bought, waaay back when, this spring. Any solutions for midpipes that use high flow cats? Original plan was to keep pre- and post-cat O2 sensors, but maybe options have changed...
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
      02-02-2016, 02:30 PM   #11
Drives: M2 Comp
Not much has changed.
Either modify the OE section or find a DKF for sale.
