      03-29-2013, 11:55 AM   #1
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
Quick question - Z4 M
From my research online it seems that there is no sound tube/generator in the Z4 M. Correct?
      03-29-2013, 11:56 AM   #2
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Correct - not required...
2006 Z4MC - #LL93158
      03-29-2013, 12:02 PM   #3
Swashplate
Swashplate's Avatar
Drives: in Anger.
Although there is active sound....it is generated by the engine. AHAHAHAHAHA
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs
1217/1815
!!! BOILER UP !!!
      03-29-2013, 12:28 PM   #4
gferil
gferil's Avatar
30
Drives: 06 Z4MC
One of the forum members did a retrofit of the sound tube to an M, and I rode in his car. It sounded cool, but not nearly as cool as an AFe or GruppeM. I think it would be something to do if you want to keep the intake stock and just want a bit more noise, but to be honest, you could only tell a difference around 3-6K if you are really on it, otherwise it sounds mostly the same in other RPM ranges.
      03-29-2013, 12:31 PM   #5
Swashplate
Swashplate's Avatar
Drives: in Anger.
The AFE sounds amazing.
1217/1815
!!! BOILER UP !!!
      03-29-2013, 12:42 PM   #6
intoflatlines
Thanks. The reason I asked is because the stock motor sounds so amazing... not sure if it's the variable valve timing, ITBs, or whatever, but it sounds so beastly and powerful from inside the cabin that I was wondering if it was some sort of fake sound being piped in like in some other modern cars. Good to know that the sound I was hearing was pure M power
      03-29-2013, 01:41 PM   #7
silverfishZ4M
Drives: 2007 Z4M Coupe
Nope, checked into this when I was researching it on my 2013 Golf R (which does have it)
      03-29-2013, 02:45 PM   #8
intoflatlines
Yep. My 2011 GTI had the "soundaktor"... it was a quick delete
