01-24-2014, 01:38 PM | #23 |
Rep 711
Here's some 5630's. Pack of 6 though. Anyone local want some bulbs?
http://www.amazon.com/Amico-White-Ga...ywords=smd5630
|Evolve Airbox - Euro Headers - Strömung Exhaust - H&R Coils - 19" BBS CH-R| |
01-24-2014, 01:41 PM | #24 |
636
Rep 3,124
Next time I buy some I'll pick something from this assortment.
01-28-2014, 08:41 PM | #25 |
Rep 711
Got the bulbs in today. The before and after.
|Evolve Airbox - Euro Headers - Strömung Exhaust - H&R Coils - 19" BBS CH-R| Last edited by Devious21; 01-28-2014 at 08:49 PM.. |
01-28-2014, 08:52 PM | #26 |
Rep 711
The Residual Effect in the light. The location of the bulb is noticable and the effect isn't very prominent.
But at night it looks great.
01-28-2014, 10:43 PM | #27 |
Rep 2,866
Looks great at night...but a white light is almost invisible during day time. One reason why I kept my amber on all turn signal indicators.
01-28-2014, 11:47 PM | #28 |
636
Rep 3,124
Looks great, and you got the glow on!
XMetal, you're in SoCal, too, so you realize that around here the side turn signal just tips off the guy in the lane next to you to floor it and block you out.
01-28-2014, 11:52 PM | #29 | |
Rep 711
01-28-2014, 11:57 PM | #30 | |
Rep 711
Now I gotta do the three corner bulbs so they match. I'm assuming those bulbs are monitored? Not sure if I can do LEDs there.
01-29-2014, 12:13 AM | #31 |
636
Rep 3,124
Looks like yours glow more than mine do. What bulbs did you end up getting?
I changed the WY5W in my front corners to W5W. The LEDs I tried at the time were too big in diameter, and I was afraid I would get it in there and not be able to get it out. I didn't want bulbs rattling around loose in the headlight assembly.
01-29-2014, 12:22 AM | #32 | |
Rep 711
I ended up getting the ones I linked above. http://www.amazon.com/gp/aw/d/B00CWA...omotive&sr=1-1
01-29-2014, 12:45 PM | #34 |
Rep 228
Devious FWIW I had the red eBay film on my tails (e85) and they faded after a while. In the past I've used www.laminx.com so I went back to that, ordered it last week for this summer. It's much higher quality stuff than what I got from eBay
bags are for groceries. |
01-29-2014, 01:49 PM | #35 |
636
Rep 3,124
FWIW I have Headlight Armor on my headlights.
It started out blue, but after a year it's clear. I think they have tail light film, and it will probably do the same.
02-01-2014, 08:44 PM | #36 | |
Rep 711
I wanna do all six bulbs.
02-01-2014, 10:08 PM | #37 |
Rep 2,546
Are you going to do amber or white?
02-01-2014, 10:10 PM | #38 | |
Rep 711
02-02-2014, 10:59 AM | #39 |
Rep 2,546
02-02-2014, 11:43 AM | #40 |
636
Rep 3,124
The corner markers are unmonitored and the lens is clear. You can go nuts on those.
The two across the bottom are turn signals, are monitored, and have amber glass lenses inside.
02-02-2014, 12:25 PM | #41 | |
Rep 711
I'll just have to figure out which LEDs to try for the h21's. Was thinking maybe these? http://www.amazon.com/gp/aw/d/B009I2...EyJj3qEvIKgP/Z
02-16-2014, 04:16 PM | #42 | |
Rep 711
So moving on, what do you think about these? http://www.ebay.com/itm/2x-White-Err...b0d874&vxp=mtr Do they look right for the 4 I need up front?
02-16-2014, 10:22 PM | #43 |
636
Rep 3,124
I researched this quite a bit last night after having to replace an inboard front turn signal.
What an ordeal. Took me about half an hour. I see 3 possible problems with the ones you're proposing. 1) I'm pretty sure the base on the H21W in the front turn signals is a BAY9s, (not BA9s, which is straight across like on the angel eyes). Looks like those are BAX9s. They have a different angle on the pins. 2) The H21W has 600 lumens. That's a lot of punch. You may find these to be too dim. This is the closest thing I've found, 300-400 lumens, but I don't know if the heads will fit into the fixture, and there's little doubt they'll cause an error. 3) The front turn signals are also run at low power as marker lights. Results will be unpredictable with LEDs. I wouldn't call this a major concern. I don't know how they're dimmed. If they're run at partial voltage, the LED might not light at all. If they're pulsed, it may work just fine.
02-16-2014, 10:38 PM | #44 |
636
Rep 3,124
I'm seriously considering the Bimmian LED rear turn signals, and maybe the 1156/7506 LEDs for the main brake lights.
But I have the "panic brake light mod" and I'd hate to put LEDs in the main brake lights and have H21Ws in the panic lights. So I'm thinking about putting the 50W CREEs in the panic lights. Don't really have to worry about a bulb out warning with those. You only get it under actual panic braking, and it clear's by itself after <60 seconds. And if they're not as bright as the H21W, that's OK too. They'll balance better with the main brake lights. With the H21Ws, they're like death rays. Maybe tomorrow I'll have a look and see if the heads are likely to fit into the fixture. They don't give dimensions, but I think I can estimate from the picture.
