      04-13-2009, 08:26 PM   #1
tom_48
BMW Novice
tom_48's Avatar
Drives: M Coupe
2007 M Coupe'  [0.00]
RPI Skid Plates?
Where can I get them, for how much, and how is the installation???
Thanks
      04-14-2009, 12:08 AM   #2
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
you can get them here
      04-14-2009, 02:28 AM   #3
tom_48
BMW Novice
tom_48's Avatar
Drives: M Coupe
Thanks a lot
Installation isn't that difficult, right? How much do you think it will cost at some average auto shop???
I'm asking b/c, for the first time, today I left my M at an auto shop. They are supposed to fix the dent in my lower bumper that happened to me at a local car wash (the car wash is paying for it). If they do a good job, I'll order the skip plates
      04-14-2009, 08:32 AM   #4
Black///Mamba
Black///Mamba's Avatar
52
Drives: a beast
lol, you can do it urself. you need 2 unscrew 2 bolts, put the skid plates in, re-screw them.
      04-14-2009, 08:40 AM   #5
Z4MHawk
Z4MHawk's Avatar
Drives: '06 Z4 M Roadster
How many would recommend these skid plates and do they fit both the coupes and roadsters? Seems like a good idea...
'06 Z4 ///M Roadster: Silver Gray Metallic; Gray soft top. Zeckhausen CDV. ESS VT1 445 Supercharger. APEX ARC8's. Dunlap Direzza Star Spec's. Strong Struts. Royal Purple. RPI Exhaust w/ DKF hangers.
      04-14-2009, 01:04 PM   #6
Leonardo629
Taiwan
168
Drives: 2013 M3 Coupe
You just need a 8mm socket to install the plates. Remove the two factory bolts, fit the plates, adjust, bolt everything up.
Highly recommended.
      04-14-2009, 02:00 PM   #7
tom_48
BMW Novice
tom_48's Avatar
Drives: M Coupe
If it's that easy, I'll probably do it myself!
So, do you fit the plates to the very edge of the bumper, or the bolts will show you where it's supposed to be?
      04-14-2009, 02:13 PM   #8
Z4MHawk
Z4MHawk's Avatar
Sounded good enough that I ordered a set. They are configured for both models (as we would assume since they have the same undercarriage). I would also like to add the clear bra to keep the front end as clean as possible. Maybe next month after my contribution to US treasury.
It takes at least one curb to figure out the safe parking distance!!!
thanks to nmulax for the link
      04-14-2009, 09:48 PM   #9
tom_48
BMW Novice
tom_48's Avatar
Drives: M Coupe
Just ordered mine, too
      04-14-2009, 10:26 PM   #10
Z4MCJJ
Z4MCJJ's Avatar
Drives: Z4MC
A second grade level of education should be sufficient to install these....
      04-14-2009, 10:30 PM   #11
tom_48
BMW Novice
tom_48's Avatar
Drives: M Coupe
I think I have that, LOL
      04-18-2009, 09:34 PM   #12
Z4MHawk
Z4MHawk's Avatar
Plates went on fine tonight. Getting the car lifted was the tough part. I had hoped they would habe been slightly bent up (rounded) along the leading edge but this will do. The center spoiler could also use a strip....
      05-23-2009, 10:19 PM   #13
chickdr
Drives: 2006 M Roadster
Getting the car lifted? You can easily reach the screws with the car on the ground... I did it in 5 minutes in my garage.
      05-23-2009, 11:14 PM   #14
fatmatt0116
Hooligan
fatmatt0116's Avatar
Drives: 2014 Porsche Cayenne Turbo S
I heard the skid plates are worthless as they don't sit flush against the underside of the bumper.
2011 X5 5.0 Dinan - SOLD
2007 Imola Red Z4 M Coupe -SOLD
2004 Navy Blue BMW 325Ci
      05-26-2009, 07:26 AM   #15
AtoB
AtoB's Avatar
Drives: Z4M
read this.... it happened to me when i got them... my opinion, they are a waste and can create more problems than the solve.
http://www.zpost.com/forums/showthre...&highlight=rpi
      08-13-2009, 04:34 PM   #16
Michelle@RPI
World Traveler
Drives: M5
The skid plates do lay flat on the car or else they would plain out break off.
Their main design is to take the scrapes the body of your car would anyway. You can drive slow around every bump but you won't be able to avoid all of them.
Michelle Hodges
Race Precision, Inc. (RPi)
For optimal performance, aesthetics, and sound, shoprpi.com!!!
      08-13-2009, 09:06 PM   #17
Twisted Six
Twisted Six's Avatar
Drives: Z4si-coupe
I've often wondered why RPI didn't offer a counter-sunk hole for flush-mount fasteners for their customers instead of having them rely on the very protruded OEM bolts ?
Also..a slight 90 degree bend as a leading edge would have been using some product foresight.
The customer can always re-spray with paint as needed to keep cosmetically nice.
      08-14-2009, 04:06 AM   #18
Leonardo629
Taiwan
168
What kind of paint should I use if want to "refresh" my plates a bit? Better, where can I have the plates made in delrin (most motorcycle frame sliders are made of delrin)
      08-14-2009, 04:37 PM   #19
Twisted Six
Drives: Z4si-coupe
SEM brand semi-flat trim paint works great.
There are a few types of Delrin....some white,some blk but I believe its called something else..slips my mind.
A piece of Delrin would slide fine over concrete or asphalt...but would also allow a faster cut-in that could eat away at the fasteners.
I've got a thin sheet of Titanium back at the Lab...I should make some from that so I can freak others out when scraping at the track with the pretty colored sparks that will fly !!
      08-18-2009, 06:39 PM   #20
blender
Custom User Title
blender's Avatar
Drives: black
Tip on appearance of skip plates
I like the plates, but the powder-coating on them is thin and fragile. The plates are bright aluminum underneath. My alignment guy bent one plate pulling onto his lift, so I bought a second pair and use the remaining good one as a spare. The plates are symmetrical and fit either side of the car by turning them over.
I found that the cheap door-edge molding in black sticks nicely over the front edge of the skid plates and usually prevents taking off the black powder-coating in the event of a scrape. It's nearly invisible and it's easier/cheaper to replace the molding than repainting the skid plates every time it happens.
Overall I recommend the plates - much cheaper than a new bumper.
      08-20-2010, 03:56 PM   #21
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
so...i was looking today and it seems rpi doesn't make skids any longer? or am i just not seeing it anywhere.......
also... crfine...how's that little project comin? lol
      08-26-2010, 11:03 AM   #22
crfine88
crfine88's Avatar
441
Drives: E86M
Slow but sure
