      10-12-2010, 12:35 PM   #1
zKnuds3712
zKnuds3712's Avatar
Drives: 2003 Z4
Proper Trans fluid
I searched through almost every section on here and could not find a straight answer. I also read through my owners manual very thoroughly. If anyone knows the correct weight or fluid type for the 2.5i trans please post it. I read somwhere that our trans use ATF?
I just realized i posted this in the DIY, sorry!
      10-12-2010, 01:45 PM   #2
lstratos
Drives: Z4 3.0i
Every model is different - so I heard, jack up the car, look for the transmission and there is a sticker that tell you what type it is.
I found my sticker but can't find a good price on the fluid. Theres like Esso, Pentosin
Its also very confusing because certain fluid that was one certified are no longer - manufacturing formula changes, etc.
According to bav auto, your car may uses the Automatic Transmission Fluid - ESSO LT71141 - 1 Liter , needs 5.5 liters.. 21.95 x5. You might need to do more searching and check your tranny before doing your change
      10-12-2010, 01:48 PM   #3
lstratos
Drives: Z4 3.0i
More fluid options
http://www.ecstuning.com/BMW-Z4-2.5i...mission/Fluid/
Reference this, there is a green label, yours might be different
http://www.z4-forum.com/forum/viewtopic.php?f=12&t=3294
So when I say its confusing, it is..
Valvoline maxlife as of 2008 lists BMW LT71141 or LA2624
On the current website with revision 07/2010 - BMW is not listed anymore
http://www.valvoline.com/pdf/Maxlife_ATF.pdf
Luckily for us, castrol has a multi import atf fluid
http://www.castrol.com/castrol/secti...tentId=7028224
Tech specs : http://www.castrol.com/liveassets/bp...s_ImportMV.pdf
I would use castrol if I can't get the original
      10-12-2010, 08:35 PM   #4
zKnuds3712
zKnuds3712's Avatar
Drives: 2003 Z4
awesome thanks for the info!! I'll be doing the oil tomorrow anyway so I guess that will be a good time to look for that sticker. I think im going to give the royal purple a shot, and their website has some good info as well http://royalpurple.com/transmission-chart.html
So hopefully my research will match up with what royal purple has to say!
      10-13-2010, 01:11 PM   #5
zKnuds3712
zKnuds3712's Avatar
Drives: 2003 Z4
hmm so I looked and could not find anything? according to royal purples chart this means I need SHC-630. Correct me if I am wrong
      10-13-2010, 08:14 PM   #6
lstratos
Drives: Z4 3.0i
No label ? Mine looks like this
Click here for larger pic
Check here http://forums.bimmerforums.com/forum...d.php?t=830669
E85
Z4 3.0 from 9/02 production to present
Z4 2.5 from 9/02 production to present
No subsequent transmission fluid changes are necessary. Never mix any other oil with this transmission fluid when doing repairs or topping up.
ESSO LT 711 41, BMW Part No. 83 22 9407 807.
Of course I can't vouch for it..
      10-13-2010, 10:08 PM   #7
zKnuds3712
zKnuds3712's Avatar
Drives: 2003 Z4
do you have an auto or manual? because that looks nothing like mine unless im looking in/at the wrong place. But im pretty positive i know where and what a trans looks like!
      10-13-2010, 10:20 PM   #8
lstratos
Drives: Z4 3.0i
Mine is auto.. assuming you ask about ATF. Mine is shell m1375.4 ATF fluid.
It's probably easier to just take a digital camera and take pics from the bottom from all angles and figure it out on the computer than to stick your head under there.
Heres another one
      10-14-2010, 09:25 AM   #9
zKnuds3712
zKnuds3712's Avatar
Drives: 2003 Z4
whoops! I see now that i failed to mention in my original post I have a manual
Thanks for the photo suggestion, I cant believe I never thought of that
      10-16-2010, 04:13 PM   #10
lstratos
Drives: Z4 3.0i
i think manual u can just dump in any mtf, others should chime in, i think its easier to do than auto
