09-11-2016, 04:52 PM | #1 |
Rep 11,667
FYI - DKF section 1 vibration
Do you have a mysterious vibration?
I had a minor vibration issue that occurred this week. It was mainly noticeable at idle. When investigating, I found that the welds for the tabs that joined the two S pipes in the section 1 had failed on one side. This allowed the tab to vibrate against the pipe. The quick fix was to just bend the tabs up a bit to give them more clearance to the pipe.
09-12-2016, 12:58 PM | #2 |
Rep 5,328
thats not good!!!
09-12-2016, 06:43 PM | #3 |
Rep 11,667
Might be something to address in the off season.
If you have someone that can do a bit of TIG its a quick fix. It can be done on car as the missing welds are on the bottom side.
09-13-2016, 09:30 PM | #6 | |
Rep 11,667
It was superposed to be an enhancement that reduced drone by joining the pipes. On the plus side its likely easier to align things.
09-14-2016, 06:03 AM | #7 | |
Rep 439
The perforated metal sheets inside the resonators on my set appeared to be unfixed, so I'm thinking the pipes not being welded allowed for too much lateral flex under load, which caused the rattling. I'm not sure if those sheets were like that by design, but that was my situation.
Remote Start /// LEDs /// 20% Tint /// SGT Headers /// Gloss Black Roof /// Aero Sides DKF Resonated S1 /// Mstache V2 /// Rear Diffuser /// CF Mirror Covers /// Eventuri Intake MRR GF7 Wheels /// Evolve Tune /// CF Spoiler /// Michelin PSS |
inTgr8r2431.50 |
09-14-2016, 07:23 AM | #8 |
Rep 11,667
I'm running CATs.
Just got back from a track day and noticed more exhaust noise (different) on the way home. May be similar to you, I'll investigate further today.
09-14-2016, 06:00 PM | #9 |
636
Rep 3,124
Which was a big plus with the RE. The fit's a little iffy.
09-15-2016, 10:11 AM | #10 |
Rep 11,667
Update
OK I just put the car on the hoist & here's what I found.
This area looked fine when I bent the tab up for clearance. The weld break obviously weakened or tore away part of the pipe wall. After running all day at the track it finally popped through. Looks like I'll be taking it in to get the welds re-welded.
09-15-2016, 12:31 PM | #11 |
Rep 1,443
Wow. Hope Doug never uses that weld shop for ANYTHING ever again if he's got more projects in the pipeline. Hope this all gets worked out easily for you!
09-15-2016, 12:44 PM | #12 |
I plead the 5th.
523
Rep 1,519
I purchased my DKF S1 second hand and before installing, noticed a crack in one of the welds. I had it re-welded and installed, but I wonder if this is an issue that may come back. Maybe this is caused by the cross braces holding the pipes too much in one place, not allowing for flex of fitment of aftermarket components, temp change, etc. Sorry to see it broke though inTgr8r, thanks for posting up.
-Matt
09-15-2016, 01:35 PM | #13 | |
Rep 11,667
I have someone that can do a bit of TIG for me, the worst part is that it will have to come off the car. .....again lol
09-16-2016, 02:28 AM | #14 | ||
Rep 439
09-16-2016, 07:39 AM | #15 | |
Rep 11,667
I hate those needle in a haystack type problems, I'll deal with ones like this any day.
12-21-2016, 09:40 PM | #17 |
Rep 11,667
DKF are no longer around, Its no longer available.
...unless one comes up in the classified section
12-23-2016, 12:14 PM | #18 | |
Rep 2,176
12-30-2016, 11:27 PM | #19 |
Rep 270
12-31-2016, 08:02 AM | #20 |
Rep 11,667
Not that I noticed.
