      12-05-2017, 05:13 AM   #1
pcube
pcube's Avatar
58
Drives: Z4MC, G20 320i
Seat belt deflector - what is that extra piece??
I'm trying to replace the seat belt deflector (part number 52107898478) on my coupe and I found a picture of it online. It has got this extra piece of plastic wedged between where the seat belt normally goes through and basically keeps it open.
Any idea what that extra piece is supposed to do?
      12-05-2017, 07:23 AM   #2
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
I first thought ECS had the wrong image, but after looking at this again, I think that's just a throw-away piece of plastic. You remove it, place the seat belt into the slot, then close it up. You can see where the little piece to the left fits into the larger piece below.
Salty
      12-05-2017, 09:20 AM   #3
pcube
pcube's Avatar
58
Yea I understand how it would work without that extra piece... didn't think it was meant to be discarded though, coz it looks like some engineering thought went into it.
      12-05-2017, 10:47 AM   #4
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Hmm I should go have a look at mine, mine busted. Brittle as hell that stuff.
      12-05-2017, 12:00 PM   #5
SaltyNC
SaltyNC's Avatar
370
I'm sticking to my theory that it's a well-engineered German packing peanut. If you find otherwise, please let us know.
Salty
      12-06-2017, 12:28 AM   #6
pcube
pcube's Avatar
58
Maybe that flap positions the belt lower so that it isn't constantly trying to strangle the driver? Will update once I receive the part.
      12-06-2017, 06:37 AM   #7
VindieselJetta
Drives: Z4m
I’m going to order one to find out, mine is also scratched. Is there a left & right version or is it just 1 part number?
      12-06-2017, 08:20 AM   #8
pcube
pcube's Avatar
58
Different part numbers each side.
52107898477 belt deflector left
52107898478 belt deflector right
      12-06-2017, 09:29 AM   #9
kaybat
kaybat's Avatar
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
little confused, is that this thing? 'cause mine squeaks like crazy
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
      12-06-2017, 10:59 AM   #10
pcube
pcube's Avatar
58
Yep that's the one
      12-19-2017, 09:05 PM   #11
VindieselJetta
Drives: Z4m
Hi all - to follow up, it is a well engineered packing peanut :-). Just holds the clip open. New clip was easy to replace and came with three new screws, which were significantly smaller (less long) then the original three, oddly enough.
2006 Z4MR
2016 Tacoma Off-road
Tampa Bay, FL
SaltyNC369.50
      12-20-2017, 06:59 AM   #12
VindieselJetta
Drives: Z4m
Pic
2006 Z4MR
Tampa Bay, FL
SaltyNC369.50
      12-20-2017, 09:43 AM   #13
pcube
pcube's Avatar
58
Haha thanks for following up. Still waiting on mine...
      12-20-2017, 11:47 AM   #14
VindieselJetta
Drives: Z4m
Np. Where did you order from? ECS had mine within 2 weeks.
2006 Z4MR
Tampa Bay, FL
      12-21-2017, 09:16 AM   #15
pcube
pcube's Avatar
58
Shipping it from Germany to Singapore, gonna take a while.
      01-11-2018, 08:20 AM   #16
pcube
pcube's Avatar
58
My package finally arrived... and sadly, that part is simply a packing peanut. I tried many ways to make it work but failed. Mine also came with the shorter screws which are about half the length. Didn't feel secure at all so i reused the old screws.
