04-13-2010, 04:48 PM | #1 |
Rep 22
Z4 Roadster Roof Question
Hi,
Picked up a 2008 Z4 Roadser from a BMW dealer today and after I press the button to put the roof down and it's completed its motions, I have a red flashing light on the "down" button. Is this just warning me that the roof is down (which is quite obvious) or does it mean there is a problem? Does anyone else get a red flashing light or had one in the past? Thanks, Lee |
04-13-2010, 04:54 PM | #2 |
Rep 374
typically it means it's not all the way down. on mine, the top stops at the rest point but the motor keeps working for a second or 2. i have to wait until the motor stops working for the top to be "completely down" and not have the light flashing. this has confused a few people who have driven my car (without me) and asked me why it flashes. so it may be the same situation since you're new to the car also
04-13-2010, 04:59 PM | #3 | |
///M'n it Up
17
Rep 344
See the owner's manual for instructions. |
04-13-2010, 05:31 PM | #4 |
Rep 22
Thanks guys but I kept the button pressed down for at least 20 seconds after the roof had completely finished opening and the red light was still flashing. The motor was continiously making the noise until I let go of the button. Light was still flashing although the roof appeared to be completely down. Tried several times.
Maybe I should take it back to the dealer and have them investigate the fault. Maybe its a sensor or something. |
04-13-2010, 07:16 PM | #5 |
Rep 4,057
Congratulations on the new car!!!!
As its a 2008, I expect you still have warranty left. On my car, when you press and hold the roof down button, both windows come part way down, the roof opens, and then after a moment, the windows go all the way up. At that point, my red light stops flashing. If things seem wrong, call the dealer's service department and chat with one of the guys there. I'm sure they can help you out!! And once more - congratulations!!!
Huz-Z
04-13-2010, 11:38 PM | #6 | |
Car Geek
3626
Rep 3,593
04-14-2010, 08:05 AM | #7 | |
Rep 11,667
Sounds like it needs adjusting. or... the tray under the top section in the trunk, isn't all the way down into position. |
04-14-2010, 11:56 AM | #9 |
Free Thinker
16949
Rep 7,455
Bet that's it.
04-15-2010, 09:49 PM | #10 |
Rep 112
This is how the top operates. Starting with windows up, top up. Press and hold top down. Window comes down half way, top unlocks, retracts, locks (at this point, process is complete), windows up.
Flash red is incomplete process (you may have let go too quickly, top has not lock in the down position), repress and hold top down button again. Flash orange (trunk storage issue). The top will not move at all if it flashes orange. |
04-22-2010, 06:45 PM | #11 |
Rep 7
So come on leeuk10, what's the story?
Don't you just hate it when you try and help people, then they just don't respond? Did you get it fixed? Should we all start to worry brethren? :-o |
04-23-2010, 04:07 AM | #12 |
Rep 17
What? Are the windows supposed to go back up automatically after the roof is lowered or raised again for that matter? My windows just go down 1/2 way and stays there....
04-23-2010, 08:12 AM | #13 |
Rep 112
No, they stay there. If they went back up you would risk being caught by the "Convertible Police" who will stop and levy a heavy fine against anyone caught driving a convertible with the top down but the windows up.
04-24-2010, 05:08 PM | #14 |
Rep 17
04-24-2010, 06:41 PM | #15 | |
Rep 165
If the space tray in the trunk is not all the way in the down position (or the switch doesn't tell the ecu that it is), the top will not move. If the OP is holding the down switch for 20 seconds after the top is down and the led is still flashing, I agree with earlier posters that the microswitch that tells the ECU that the top down is the culprit. A follow up post from the OP as to the resolution would be appreciated. |
