10-03-2010, 09:10 AM | #1 |
Looking for a track car
Rep 242
Drives: 2006 325xi wagon
Stock muffler mod out there?
Since I was bored yesterday and running without mufflers, I decided to open up a muffler to see what I can or can't do with it. Will most likely pull out the glass and reseal to start with. See where that goes. Also plan to paint the bottom and tips semi-gloss black. I was amazed at how much glass is packed in all the chambers. Once I put these back together, I will remount to see if this was just a waste of time.
10-03-2010, 03:08 PM | #2 |
Rep 503
Drives: Z4 M Coupe
Sounds like an interesting project. Maybe post some pictures if you have any?
10-03-2010, 03:20 PM | #3 |
Rep 108
+1 very interested to see what the stocker looks like on the inside.
I've been toying with the idea of running a straight tube internally from the inlet to one of the two tips. By swiss cheesing this tube & using an external bypass valve you'd end up with a dual mode muffler. Similar to this flowtech design http://www.holley.com/types/Warlock.asp |
10-03-2010, 03:42 PM | #4 |
Rep 242
Well, I was contemplating a straight pipe but since I have been running muffler-less for the past couple of weeks I decided to do this project. Straight pipe/no pipe is too ricey and loud. Not sure what to expect from this mod but will see tomorrow when I get a chance to remount.
Very easy, really just needed the time during the past 2 days to do this. I first picked the top side due to the welds that would hold the panels in place after I did my cutting. Also, because I did not want any evidence that this had even been done when it is lifted, checked, eyeballed from below. Picked my lines and cut with a grinder. ABout 20 minutes for each one, tops. Look how much friggin glass is packed into just one of these!!!!!! Once the glass is removed, the cuts are metal patched with the liquid equivalent of welding. I plan to leave these unfinished until I finalize what the hell this project is even getting me, lol. Primed after metal patching. Final coat of low gloss black, no clear coat until I know for sure I plan to keep this setup. Here's what the upper side will look like, roughly. Unfinished for now.
10-03-2010, 07:13 PM | #8 |
Rep 698
I'm getting ready to do cutouts right before the mufflers on mine.
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
10-03-2010, 09:46 PM | #9 |
Rep 1,739
Drives: 2008 Z4MC
10-03-2010, 09:54 PM | #10 |
Rep 698
Anybody know the size of piping on stock mufflers? I was guessing 2.5 i.d. and was gonna go with a set of these right before both mufflers and turn them to where the exit is facing the wheels on each side. Gonna secure the caps with wingnuts so I can remove or recap them by hand and have easy access.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
10-04-2010, 08:38 AM | #12 |
Rep 12,565
looks good but how does it sound???
10-04-2010, 09:25 AM | #13 |
Rep 242
Didn't take any shots of the innards. Thought that was a given, maybe not.
Hopefully remounting tonight, and may get a sound check. We'll see. Weather sucks today through Wednesday.
10-04-2010, 10:13 AM | #15 |
Rep 2,431
hmmm....are there any baffles inside or is it perforated tubing w/ filler on the sides? I would probably get that welded shut after you decide to keep it, as the JB weld may accumulate leaks down the line.
Food for thought, my dirtbike has a muffler that requires packing every so often. And it's dyno proven hp when packed over being empty....but then again, we're just in it for the sound
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
10-05-2010, 01:20 PM | #16 |
Moderator
497
Rep 27,441
wow, that's a lot of packing!
too bad you didn't get any pics of the internals. looking forward to hearing how it sounds.
10-05-2010, 01:25 PM | #17 |
John 14:6
59
Rep 587
Me too! Please post some update pics and a video once the project is competed.
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover... |
10-05-2010, 05:08 PM | #18 | |
Smiling Politely
1381
Rep 29,118
hmm this with headers..??
wonder what that sounds like.
10-05-2010, 05:48 PM | #19 |
Rep 242
That was a complete waste. Sound is stock, the same as with the glass packed in.
Well, at least I know it's a three chambered system to mess with. Will sleep on it and figure a boring option between pipes and chambers. Dumps are just too loud for me, and stock just won't cut it.
10-05-2010, 06:21 PM | #20 | |
Rep 2,431
If your dead set on getting a custom setup, I'd recommend starting w/ the delete and then add a muffler from there on.
10-05-2010, 11:58 PM | #21 | |
instagram 997turbotom
279
Rep 7,377
10-13-2010, 09:25 PM | #22 |
Rep 231
How much did each muffler weigh... do you know?
I'm considering a muffler delete for weight, but want to avoid droning and excessively high noise levels. Probably delete my muffler, run it all the way out, and then go from there with perhaps a Supersprint if it drones too much or is too loud. Great posting by the way. You should come to Fedex Field and join us at WDCR SCCA.
FS: Leather Recaro Pole Position Seats & Hardware |
