08-21-2010, 01:17 AM | #25 |
Rep 6
so...three weeks outside warranty, one of my corona lamps went. Can anyone confirm the part #15 is the correct part that lights the inner ring? The part appears to be attached via 2 screws. Do I need to undo the screws to change the bulb or is there a way to 'twist' the bulb only loose? I'm impatiently waiting for my technical service DVD, hopefully after that no more simple questions!
08-25-2010, 10:10 PM | #26 |
Rep 22
Drives: 2006 Z4 3.0 Si
Thanks for the link, answered my question beautifully.
08-27-2011, 12:45 PM | #27 |
Rep 82
BTW, just bough $1 led lamps from ebay and they fit without modifying the socket in any way - just remove the old lamp and insert a new one.
Not sure how to remove the "lamp" warning on the dash. The LED lamp was a "canbus" one |
08-27-2011, 01:53 PM | #28 |
Rep 2,866
Drives: Anything
Do you have pictures of the OEM lamp and the LED lamp that you're replacing it with?
08-27-2011, 05:47 PM | #29 |
#dubspec
6336
Rep 5,201
pics of them lit up? any brighter than stock bulbs?
08-27-2011, 06:46 PM | #30 | |
Rep 919
Drives: BMWs
Garage List 2008 E60 M5 6MT [0.00]
2019 G01 X3 sDrive30i [0.00] 2007 E86 M Coupe [0.00] 1997 E36 M3 [10.00] 2006 E53 X5 4.8is ( ... [0.00] 2006 E85 M Roadster ... [0.00] 2002 DINAN 5 (sold) [0.00] 2013 E89 Z4 sDrive3 ... [7.00] 2011 E92 M3 (sold) [0.00] 2001 E46 M3 (sold) [0.00] 2007 R56 Cooper S ( ... [0.00] 2002 996TT (sold) [10.00] 2009 E82 135i (sold) [9.00] 2006 E85 Z4 M (sold) [6.00] 2007 B7 A4 2.0T (re ... [0.00] 2003 E46 M3 (sold) [0.00] 2002 E46 325Ci (sold) [0.00] |
I also tried to replace mine with higher wattage bulbs (20 watts vs. 10 watts OEM) as in this thread: http://www.bimmerfest.com/forums/sho...d.php?t=417609 and the socket started to melt after a few days. |
08-27-2011, 06:49 PM | #31 | |
Rep 919
Drives: BMWs
1. remove the stock bulbs 2. insert the new bulbs |
08-29-2011, 08:57 PM | #32 | |
Rep 82
But, as I said, not sure if "electric problem" lamp will reset (I bought canbus bulbs, but they are too weak, only 5 LEDS). So now I ordered similar lamps with 25 LEDS. |
08-20-2012, 10:01 PM | #34 |
Rep 12,565
Bump anyone experience long term issues witt this, ie melting, bulb prematurely dying, etc.?
08-20-2012, 11:28 PM | #35 | |
Rep 439
And pics, please. Trying to figure out if it would be worth it.
Remote Start /// LEDs /// 20% Tint /// SGT Headers /// Gloss Black Roof /// Aero Sides DKF Resonated S1 /// Mstache V2 /// Rear Diffuser /// CF Mirror Covers /// Eventuri Intake MRR GF7 Wheels /// Evolve Tune /// CF Spoiler /// Michelin PSS |
10-28-2012, 04:53 PM | #36 |
Rep 1,991
Suprtran above said the 20W bulbs started melting the socket within days so I guess we have no good options unless someone modifies an assembly to allow LED's without setting the sensor off.
10-28-2012, 05:41 PM | #37 |
Rep 4,531
10-30-2012, 09:51 PM | #38 |
Rep 1,991
10-30-2012, 11:30 PM | #39 |
Rep 4,531
10-31-2012, 03:41 PM | #40 |
Rep 251
I messed around with my angle lights close to 2 years ago... I ended up just replacing the bulbs for blue LEDs. I'm actually pulling down the front bumper again next weekend to replace that stupid Z4 horn and I'm thinking of replacing the angel eyes again - probably red, bright orange or plain super white.... not sure yet. The LEDs bulds are like $3.oo each
However, if you replace the bulds for LEDs you will get a light on the dash. I was able to turn that off with my laptop and P.A Soft. Take a look at this link... good luck. http://www.bimmerfest.com/forums/sho...d.php?t=578193 |
11-20-2012, 02:53 PM | #41 |
Rep 428
Do you have to remove the front bumper to access the headlight? I removed the intake and i don't see how to remove the back of the headlight and replace the bulb?
Disregard...figured it out. For those that were as unsure as I was...for the driver side headlight, remove the wheel, and remove the panel in the fender liner.....from there, you pull the metal wire down, and then slide the cover off the headlight by pulling it towards you and lifting it out. Then, just turn the bulb bracket counter clockwise.....remove bulb/bracket, install new one, turn clockwise to lock it in and reinstall everything back to the way it was.
1997 /// M3 Coupe Arctic Silver CES STAGE IV (651rwhp/615rwtq)
1999 /// M3 Convertible Techno Violet Last edited by BMW Maniac; 11-20-2012 at 03:20 PM.. |
11-20-2012, 04:13 PM | #42 |
Rep 1,663
This topic is so confusing, I still don't get why no one has been able to adapt the WeissLicht lights. Is it because of the split V doesn't fit in the socket? if so it looks like it has a screw, maybe one side could be losened up, then put back into place inside the housing.
11-20-2012, 05:09 PM | #43 |
Rep 428
What is confusing is why BMW doesn't provide replacement bulbs and requires the purchase of the bracket as well....the bulb is like any other bmw bulb and socket...push down, twist and it pops right out.
1999 /// M3 Convertible Techno Violet |
05-16-2016, 11:09 AM | #44 |
Rep 47
I had a Lightbulb Error show up on the dash today. Seems like it is one of the angle eyes (passenger side). Is there a DIY out there to show an OEM replacement of the bulb? I've never worked on my car and would like to get into doing small stuff like this.
Or, is there any proven (long lasting) method of upgrading the angle eyes? Thanks. |
