12-29-2022, 10:24 PM | #1 |
Rep 1,772
Drives: Bmw 330i and Bmw 328i
e85 Water noise went operating top
It rained in socal for two days. I park my z4 outside and when i went to put the top down there was water noise. The top hasnt worked in a while so i put it down manually. I use the button to operate the top so it can unlatch and the pump makes water noise. Is this a concern?
12-29-2022, 10:33 PM | #2 |
Rep 565
Have a look at this post : https://www.zpost.com/forums/showthread.php?t=1021381
The top latch motor is electric driven opposed to the lowering mechanical from hydraulic motor. There shouldn’t be water near the latch motor, pop open the access hatch for the latch motor to check on it but shouldn’t be a way for water to get there. The soft top left hand drain runs right by the lowering motor if you search for soft top motor dying on these you’ll find plenty of results. Once water clogs it at the very least starts things corroding. The link above I’ve done and back blow the drains periodically to keep them clog free. Of your car sits outside rain water is the death of your motor. Edit: to add if your hydraulic lines/fittings break/corrode or leak it will leak from this drain as well putting hydraulic fluid right in front of your rear wheels. Last edited by Piper1; 12-29-2022 at 10:45 PM.. |
12-29-2022, 10:52 PM | #3 | |
Rep 1,772
12-29-2022, 11:21 PM | #4 | |
Rep 565
The hose I used on the bottom side is braided so it won’t kink up for water flow it’s zip tied to the lower bars so the drains will pour the water off set so not right in line with the tires. When I back blow them out with an air gun from the compressor just have to plug the air gun up and blast them clean. Total takes about half hour to set the hoses up and less than a minute to blow the drains clear with about $2 worth of hose from Home Depot. It’s prolly the cheapest least time consuming and most important maintenance mod you’ll ever do to this car. Last edited by Piper1; 12-29-2022 at 11:30 PM.. |
bob'smerlot10.50 2one3E902422.00 |
