BMW 3-Series (E90 E92) Forum
help! after c/o installation, car vibrates for short periods when accelerating
11-18-2007, 07:45 PM | #1 |
Moderator
675
Rep 4,737
i recently installed H&R street performance C/O on my 335xi coupe. everything works fine except -
when accelerating full throttle at higher gears (4, 5, 6) and low RPM ~1500-2000, car vibrates (vigorously) for around 0.5 seconds initially. and after the vibration, everything goes back to normal. and no, this is not because i am driving over a bump... i am a mechanical engineer, so technically speaking, it feels like the new suspension changed the natural frequency of the car, and when the engine is at a certain speed and transmission in a certain gear, the car resonates with the frequency of the engine. thus the entire car vibrates. any suggestions on what i can change? Last edited by rzm3; 11-18-2007 at 11:04 PM.. |
11-18-2007, 07:46 PM | #2 |
Rep 4,244
might want to check if everything is bolted on correctly.
2010 E92 BSM 335i | M-Sport | ST Coils | Linea Corse Lemans | Cobb AP | BMS DCI | Cyba Tips
11-18-2007, 10:33 PM | #6 |
Rep 7,719
If this was bump related..it wouldn't have gone away and would only progress as he picks up speed. I have some friends who have cars that are unbearable over bumps, to the point where you have to support your butt with your hands because it's that stiff.
To the OP, take it to a reputable shop to have the install looked at if you are sure if the coilover. I've helped out with many coilover installs, over 10 easily, and never heard of this though. |
11-18-2007, 10:51 PM | #7 |
Moderator
675
Rep 4,737
11-19-2007, 01:20 AM | #8 |
Rep 4,244
11-19-2007, 05:11 AM | #9 |
Test here
44
Rep 374
11-19-2007, 11:44 AM | #10 |
Rep 1,675
A buddy of mine had that problem with his mini. When we took it off we were missing pieces from the manufacture. We were missing a washer and a bump stop or something like that. The coilovers were sent back and were put on again and they were fine. I blieve you are missing few pieces in the setup. One washer can make a big differnce in the whole suspension so take it off and see whats up. I hope this helps.
[SIGPIC]2015-Cayman S (Can't leave bimmerpost)
2009-E92 M3 2005-E46 M3 1998-E36 M3 2007-E92 328i[/SIGPIC] |
09-24-2008, 08:34 PM | #12 |
Modder Raider
759
Rep 8,633
Drives: M3
Please tell me you got an allignment after the install.
If not then there's your answer. My car felt great after my suspension install, but I took it to get it alligned and it was way out. EDIT This is from 2007??? I'm wondering if he ever got the alignment.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
