      01-11-2009, 11:09 PM   #1
///mpowah
Drives: 2007 Z4 M Coupe
Thumbs down DAMN second gear..
Hi All,
I have owned my M coupe for about 3 weeks now, having owned a 330i, e36 M3, and e46 M3.. i can truely say the Z4 M coupe is amazing in everyway... superior than any other M car i have driven
As the saying goes.. with the good comes the bad & the bad for me is currently the changing from 1st to 2nd gear.. with the sport on and DSC deactivated the gear box tends to grind when changing!! it is currently driving me insane - i have never had this issue on any of my other cars...and it happens constantly..
I have researched it and found quite a few Z4 owners have been complaining about the syncro's and gear box..
Does anyone have any advise or info on this issue?
      01-11-2009, 11:57 PM   #2
M2audioman
Drives: 2018 M2
After 20K miles on my car, the problem seems to have gone away for the past few months...It is annoying though and tough to replicate consistently, hence the reason i was unable to have a new tranny installed by the stealership...
The problem is that the Z4M uses the Z4 3.0si transmission instead of the M3's. Makes no sense to me as to why they did that, but it is definitely a flaw.
      01-11-2009, 11:59 PM   #3
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
Hmm, I've never had a problem with grinding; it tends to be a bit finicky when shifting from 1st to 2nd, but you just have to smooth it out. Stupid question, but you're sure you're depressing the clutch fully?
      01-12-2009, 12:08 AM   #4
M2audioman
Drives: 2018 M2
Im pretty sure he is. This is a very common problem on Z4M's...Here is more info...
http://www.zpost.com/forums/showthre...ighlight=grind
      01-12-2009, 12:15 AM   #5
rcube
Drives: z4mc
you got to slow down the shifter movement... use the force..you have to feel for it
      01-12-2009, 02:10 AM   #6
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Drives: 997S, MV Agusta F4, E46 M3
How many miles on it? When was the last time all the gear fluids were replaced?
I haven't had the problem. I wonder if those who do unload the motor before shifting? In other words, back off the throttle a bit first. I don't really like to rev the car in first to redline anyway. I don't do that with my bike either. It's sort of abusive ultimately.
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU
      01-12-2009, 05:36 AM   #7
rc'Z
Drives: 2009 335i Convertible
Wouldn't that suck to have to double clutch a BMW to shift from 1st to 2nd!
My non-M will do likewise occationaly, 4k on it.
      01-12-2009, 08:13 AM   #8
jragan
Imola Lover
jragan's Avatar
http://www.bimmerfest.com/forums/sho...php?t=309844#2
Hers: 997-1 C4S: Pics
      01-12-2009, 08:16 AM   #9
F360C
Drives: E86 S54
My brother went as far as to get his tranny replaced by BMW on their coin and to tell you the truth it really didn't solve anything. After 28,000 miles I have to say that the grind is I think paritally caused by shiffting technique... I have learned to be shift as fast as I want with out the grind but there is a certain way you have to hold the shifter.
07 Z4 M Coupe AW/IR
      01-12-2009, 09:28 AM   #10
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
With nearly 3900 miles, the transmission is notchy in general when cold but seems butter smooth once it's warmed up; I've never had a grind either before or after the Zeck modified lock valve.
      01-12-2009, 05:23 PM   #11
BMWI6
BMWI6's Avatar
Colombia
96
Drives: 335is
this drives me nuts!!!! i just got mine and this issue is killing me,
If everything seems under control, then you aren't going fast enough"
      01-12-2009, 08:18 PM   #12
pmeloche
pmeloche's Avatar
Drives: 2013 F25 X3 xDrive35i
The shift from 1st to 2nd can be jerky at time but I never experienced a grind. After 13K kilometers, it's mostly smooth. I also never deactivate the DSC and use rarely the Sport button when not on the highway.
Patrice
2013 F25 X3 xDrive35i Vermillion Red
      01-12-2009, 08:23 PM   #13
reRESERVEDFX
(oO (||||) (||||) Oo)
reRESERVEDFX's Avatar
Drives: 06 BMW Z4 3.0i 03 BMW M5 DINAN
Once your slightly past the friction point after shifting from 1st to 2nd add a little bit of gas. That makes it nice and smooth.
2006 Porsche 911 C4S Black/Black 6MT/Sport Chrono/Extended Leather/GT2 bucket seats/Turbo wheels
Soon to come 07 BMW Z4M Coupe Black/Red
      01-12-2009, 09:36 PM   #14
Mikewarlover
Mikewarlover's Avatar
Drives: white
I have the same problem but not so much grind into second but its really unsmooth and require me to pull a lot harder than other gears i was driving me nuts just 15min ago.
      01-12-2009, 09:51 PM   #15
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Double clutching is for downshifting not upshifting.
For the OP you have to modify how you shift, you cannot jerk it into gear, you have to smoothly but firmly and evenly press it into gear. They don't like being mashed on.
Additionally if you ever try to shift into second from a wheel spin scenario, just forget about it going smoothly.
It seems dumb that we don't have the e46 M transmission, but just think to yourself, do you really want the 7 year old transmission in the car? Even the "regular" BMWs have better transmissions now.
I've considered changing the tranny oil to a redline or another premium brand a few times. Usually helps with things like this.
      01-12-2009, 10:06 PM   #16
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Oh and if you really want you can fit an e46 transmission, you'll need a new driveshaft (actually pretty easy to get made) and have to modify the shift linkage some.
      01-12-2009, 10:42 PM   #17
///mpowah
Thanks for the insight guys.. its nice to know its not only me having the issue..
anyway, booked the Z into the stealership to see what they can do to resolve the 'grind'..
will keep you all posted on the results..
      01-13-2009, 05:16 AM   #18
rc'Z
[QUOTE=O-cha;3942529]Double clutching is for downshifting not upshifting.
QUOTE]
Worked fine for upshifting in old racing transmissions that had no sycnros. Worked fine for old trucks when shifting from granny low to first gear with out grinding........oh well.
      01-13-2009, 02:02 PM   #19
Hawkeye
Hawkeye's Avatar
No_Country
2070
I thought double clutching was mainly for rev matching without wearing out your tranny? Why would you need to do that in an upshift, or am I missing a crutial reason for double clutching?
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
      01-13-2009, 05:14 PM   #20
O-cha
O-cha's Avatar
218
Drives: Mcoupe
You're not missing something, I think he is just a little confused.
      01-14-2009, 05:37 AM   #21
rc'Z
O-cha, please educate yourself, it works up, it works down:
http://en.wikipedia.org/wiki/Double_clutch
      01-14-2009, 10:41 AM   #22
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
