      10-05-2012, 10:46 PM   #1
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
5 mm front wheel spacer
I have OEM CSL wheels and thinking of getting 5 mm spacer for the front to match the rear offset better. I wonder do I need a hub extender to avoid vibration? OEM CSL wheels have bevel wheel hub that will leave less than 5 mm to support the wheels. I appreciate comments from folks running spacers.
TIA
      10-05-2012, 11:24 PM   #2
RADRACR
RADRACR's Avatar
I have 5mm spacers on rear. Dunno if that helps you.
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      10-05-2012, 11:59 PM   #3
RobMCoupe
RobMCoupe's Avatar
60
Thanks. Do you recall if you wheel hub is bevel?
      10-06-2012, 06:24 AM   #4
MFGJR
I'm using 5mm front spacers with OEM wheels that have the beveled bore, and had vibration before adding hub extenders. I went with the TMS extenders.
      10-06-2012, 09:28 AM   #5
Quickid
Drives: 08 Z4MC, 06 X5 4.4i, 99 323i
It all depends on the wheel. I have wheels with bevelled bore and I am able to use 5mm spacers without extenders.
In case you are using a stud kit, I am able to mount 74.1 wheels without hubcentric rings. The wheel centers better on studs.
      10-06-2012, 09:41 AM   #6
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
I run 5mm spacers for my track wheels (to clear the front strut w/my camber and to avoid rubbing in rear).
I run studs and never experienced vibrations
      10-06-2012, 10:16 AM   #7
RobMCoupe
RobMCoupe's Avatar
60
Thanks guys. I am getting a stud kit from RB GB. Will go with just spacer for now.
