03-02-2012, 11:46 PM | #1 |
Rep 704
Drives: '08 MC
Experiment: Coding Amps. Code your E86 amp to E85 amp specs for improved stock sound
Edit 09/16/12:
In Post #60, Pungo posts the E85 Amp Coding. This code can be used to recode an E86 amp to get the better sound that E85's exhibit. ------------------- Edit 04/17/12: Having successfully swapped amps with an e85 roadster, its been pretty clear that there is an improvement in the clarity, volume, and bass levels in the e86 coupe stock system. Much of this is outlined in this thread. -------------------- 03/03/12: Looking for anyone local to tri-state NE area willing to help me code my current E86 amp to their E85 Roadster with Top Hifi audio: Would pay for all costs and compensate for your time. Would need to put my amp in your e85 and then have dealer code it. -OR- Would need someone who thinks they can recode an amp while it still in an e86 so its coded the same way an e85 amp would be as if its sitting in an e85. (If the latter works and it makes my system come alive, that could help a lot of coupe owners with crappy sound, and possibly become a good reason to go out and recode other amps and get paid something for it) Could be done in an afternoon. Willing to travel. This Thread explains it all and is quite interesting: http://www.zpost.com/forums/showthread.php?t=611528 EDIT: A forum member with a spare e85 amp has agree'd to help me with this, loaning me the extra amp. If it works, we have worked out a swap arrangement for my current amp and some cash. And probably confirmed how to improve our E86 crappy stock stereos. Excellent! This community continues to impress me. I look forward to seeing if I can get my stereo to come alive with a simple coding swap.
03-07-2012, 09:59 AM | #3 |
Rep 258
Drives: 2008 Space Gray Z4M Coupe
Good Luck with the experiment!
03-07-2012, 11:01 AM | #4 |
Rep 704
Drives: '08 MC
Thanks! the E85 amp arrives this evening. I will get to install it in the coupe this Sunday (traveling until then), and will promptly post the results for all.
I have the patience of a Horsefly - and already broke one of my fasteners trying to get the back panel off. Anyone local that has done this and wants to join me... free beers for you, just pm....
03-11-2012, 07:13 PM | #6 |
Rep 704
Drives: '08 MC
Thx- If you have the old stock amp lyin around, thatd be good to know for the future.
03-11-2012, 07:36 PM | #7 |
Rep 704
Drives: '08 MC
Update. Got the E85 amp into the back of the car today. Install was quite easy. The quick answer: It makes a BIG difference, and there is a BIG improvement. This is a great, cheap solve.
The more winded version: Before doing the swap, I listened to 4 different songs, each thru the CD player and also thru my ipod via the aux jack. My neighbor and my wife also listened taking turns in passenger seat. SO, our baseline is now in our heads. Then I swapped the E85 amp into my E86, and listened to them all again. I did this three times, with doors/hatch closed, engine off, DSP set to Jazz (recall I have no navi), bass flat, treble +3 clicks, balance/fade all neutral, and speed volume control set at 1. Each time, we all noticed the same changes. Much clearer, harder hitting, virtually no fluttering or "blown speaker cone" sounds, and overall capable of much louder volumes and while staying remarkably clear. I will say with this E85 amp, its now one of the better if not the best sounding stock system I have heard in a BMW.... with my wifes X3 with underseat subs also ranking right up there. (I havent hear an Alpina B7 to comp, sorry). I know, it's still not a $4000 aftermarket system. But it sounds darn good and very impressive. My expectations were high, and I didnt want to be swayed by a hope or placebo effect, hence bringing 2 more listeners in and doing it 3 times over. Bear in mind I'm not an intense audiophile or a pro-critic, just someone looking for a good sounding system, and this did the trick. MHeavNC's thread "working with carver subs" (link above) explains it all, he's the one who stumbled on this - well done man!
03-11-2012, 08:01 PM | #8 |
Rep 659
Garage List 2022 M5CS [0.00]
That's great, congrats! So the coding changes EQ settings, crossovers, etc?
Funny that BMW would change the tuning. Don't any of those Germans have a good set of ears? Geez You would think they would take 20 minutes to listen to their programming selection.... Chris
03-11-2012, 08:49 PM | #9 | |
Rep 704
Drives: '08 MC
Is it possible to electronically limit the output of an Amp? For example similar to the way you'd limit top speed of a car?
03-11-2012, 10:56 PM | #10 | |
Rep 820
Drives: 2007 Z4MR silver grey
" I will say with this E85 amp, its now one of the better if not the best sounding stock system I have heard in a BMW" I agree, on it being one of the best stock systems period. If you think it sounds good with the setting at "jazz", you should here it with DSP and the adjustable 7 band graphics properly adjusted. I ran sweep tones in my car and used a DB meter and made adjustments and got the thing sounding exceptionally good. The only thing it's missing in my car (after the BSW stage one upgrade) is a little more clean power for 70 MPH cruising with the top down. Up to about 50MPH top down around town though, it rocks! I listen to classic rock, rock, jazz and blues, so the bottom end is fine for me.............. hits just fine for those genres.............. would I like a little more bottom? Sure, but I'm hoping BSW comes out with an upgraded 6.5" woofer for the kick panel that is a little tighter and more musical with equal or better efficiency sometime soon......... that should help round out things some. |
03-11-2012, 11:09 PM | #11 |
Rep 2,541
DSP_E85.C02 module values
Here is the dump of the values for the DSP module functions. E85-DSP_E85.C02-ModuleFunctions.txt
Here is the trace from my 2007 E86 top hifi DSP module. DSP from E86.txt There is also 8 different values for DSP_ACOUSTIC_PROFILE in the TCU module. E85-TCU_IBUS.C05-TraceFunctions.txt Some stuff is translated from German, some stuff is not. These modules look like they can be recoded with different values, but I have not played with changing any yet. I can see a difference in coding between E85 and E86. I use NCS Expert to read and code modules. I don't know if it helps this post in any way. |
03-12-2012, 10:45 AM | #12 |
Rep 159
Very interesting. My coupe sounded crappy with the subwoofers, so I took them out and it sounded significantly better. I also noticed a degradation in sound quality as my first battery neared the end of its life. It would all point towards a lack of power to the woofers in the coupes that causes the poor audio quality. Wonder if it would be worth looking into the e85 coding and replacing the subwoofers.
03-12-2012, 10:48 AM | #13 |
Rep 704
Drives: '08 MC
I would be curious what the difference in coding is that you are seeing -translates to in laymans terms.
03-12-2012, 04:30 PM | #14 | |
Rep 2,541
Here's an example: ECKFREQUENZ_LOUDNESS e86 PEGELADAPTION e86 HECKDELAY e85 e86 FILTERBAENKE1 e86 FILTERBAENKE2 e86 FILTERBAENKE3 e86 FILTERBAENKE4 e86 FILTERBAENKE5 e86 FILTERBAENKE6 e86 FILTERBAENKE7 e86 FILTERBAENKE8 e86 FILTERBAENKE9 e86 FILTERBAENKE10 e86 FILTERBAENKE11 e86 FILTERBAENKE12 e86 FILTERBAENKE13 e86 FILTERBAENKE14 e86 FILTERBAENKE15 e86 FILTERBAENKE16 e86 FILTERBAENKE17 e86 FILTERBAENKE18 e86 FILTERBAENKE19 e86 FILTERBAENKE20 e86 FILTERBAENKE21 e86 FILTERBAENKE22 e86 FILTERBAENKE23 e86 FILTERBAENKE24 e86 FILTERBAENKE25 e86 FILTERBAENKE26 e86 FILTERBAENKE27 e86 FILTERBAENKE28 e86 FILTERBAENKE29 e86 FILTERBAENKE30 e86 FILTERBAENKE31 e86 FILTERBAENKE32 e86 FILTERBAENKE33 e86 FILTERBAENKE34 e86 FILTERBAENKE35 e86 FILTERBAENKE36 e86 FILTERBAENKE37 e86 FILTERBAENKE38 e86 FILTERBAENKE39 e86 FILTERBAENKE40 e86 FILTERBAENKE41 e86 FILTERBAENKE42 e86 FILTERBAENKE43 e83 e85 e86 FILTERBAENKE44 e83 e85 e86 FILTERBAENKE45 e86 FILTERBAENKE46 e86 FILTERBAENKE47 e85 e86 FILTERBAENKE48 e86 FILTERBAENKE49 e86 FILTERBAENKE50 e86 FILTERBAENKE51 e86 FILTERBAENKE52 e85 e86 FILTERBAENKE53 e86 FILTERBAENKE54 e85 e86 FILTERBAENKE55 e86 CID aktiv EMPF_STATUSMELD anfrager GAE_TABELLE e86 |
03-12-2012, 05:43 PM | #15 |
Turd in the Punch Bowl
19
Rep 239
Great stuff!! All I know is that me and gtMc are very happy with the results using an amp coded to an e85.. If you can find the difference in how the amp handles navi vs non navi,.... I may have a little project for you.. Right now I have an amp in my M Coupe that is coded to a e85 non navi system.. It sounds awesome but the DSP settings and EQ don't change the sound at all.. As a side note, if you install an amp coded for a navi system in a non navi car, the DSP presets don't work.. They don't even show up on the head unit....
03-12-2012, 06:28 PM | #16 |
Rep 704
Drives: '08 MC
Pungo - thanks for posting that data. I'll look at those links you provided over the weekend and see if I can make heads or tails of it all (I have to travel again from now until then, but will look at it). So far you are the first to actually identify real differences in coding between the E86 and E85 version of the same amp. Unless we missed it in another thread somewhere. Thanks.
The other annoying part is that the dealerships claim to MHeavNC that one cannot recode an E86 amp to E85 specs, unless that amp is sitting in a vehicle that is an E85 VIN number.
03-12-2012, 06:40 PM | #17 |
Rep 704
Drives: '08 MC
I'd be very curious if anyone else out there is also able to pull off a temporary amp swap, to see if they experience a difference too. I dont want to oversell the results to anyone, but Its a noticeable difference from what I can tell.
03-12-2012, 07:36 PM | #18 | |
Rep 2,541
CID CENTRAL INFORMATION DISPLAY (CID) NAVIGATION,BORDMONITOR not active The dealer may be telling you the truth. The software they use is much different than what I'm using. The s/w I'm using is for engineering and not used by the dealer. It's much harder to code with and will allow you to do dumb stuff that doesn't even make sense or work, but that is what you need to make the changes you want. You have to edit the files to make changes and there is no error checking. It may even be possible to brick the module. |
03-13-2012, 10:02 AM | #19 | |
Rep 1,772
Drives: 2007 Z4M Coupe
Gt1?
03-13-2012, 02:00 PM | #20 |
Rep 2,541
03-15-2012, 11:38 PM | #21 |
Rep 2,541
If someone with a E85 could get a trace file from their DSP module using NCS Expert I could use NCS Dummy to show the differences between a E85 and my E86 and save the output. That will show us exactly what is different between the 2 cars. Though by looking at my E86 trace file, it looks obvious what the differences probably are.
I translated a few of the German words that may make a difference in loudness. This is the factory coding on my E86: GERADESTEIGUNG_LOUDNESS = JUST PITCH LOUDNESS value = E83 E86 ECKFREQUENZ_LOUDNESS = CUTOFF FREQUENCY value = E86 PEGELADAPTION = LEVEL ADAPTATION value = E86 Also almost every FILTERBAENKE1 through FILTERBAENKE55 is set to E86 for my E86 DSP module. Allowed values are E83, E85 and E86. I guess I could change every value that is E86 to E85 and recode the DSP with the E85 values and listen to how it sounds. It would only take a few minutes to switch between E85 and E86 coding modes. If I can find what function makes the bass louder and just code that while leaving all the other function setting alone, then this hybrid coding may make the system sound even better than just changing the all the coding of the E86 DSP to E85. I'm sure the acoustics of E85 vs E86 are much different. The BMW engineers have those 55 FILTERBAENKE to play with. I would really like to know details about those 55 FILTERBAENKE. |
