      11-17-2016, 08:56 AM   #1
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
Is an alignment needed when replacing rear dust sleeve?
Hey all,
The other day I was driving my '04 3.0i around and was noticing a little noise coming from the rear. Upon inspection, it appears my dust sleeve (p/n 33521136283) is being squished under compression, and now looks like an accordion. Best I can work out what happened is when I installed koni yellows this summer I must have biffed up putting this on correctly
Anyways, since this car is going to be used this winter (and the part is relatively easy to replace), I was wondering if an alignment is necessary after replacing the part, as I have to remove the shock. If I remember correctly, the camber and toe adjustments are independent of the shock, but I want to make sure replacing a $5 part would or would not require an extra $100 to align the car.
Worst case scenario, I wait to replace the sleeve until next year and get the car aligned right before autocross starts up again
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
      11-21-2016, 09:43 AM   #2
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
Originally Posted by jns_e85 View Post
Hey all,
The rear shocks don't affect the alignment so you're good to go replacing the sleeve.
Top Down 365
      11-22-2016, 10:49 AM   #3
jns_e85
jns_e85's Avatar
74
That's what I was thinking. Thanks!
