02-28-2016, 05:45 PM | #23 | ||
Rep 1,923
02-29-2016, 01:34 PM | #24 | |
Rep 11,667
02-29-2016, 01:36 PM | #25 | ||
Rep 1,923
02-29-2016, 01:42 PM | #26 |
Rep 11,667
The brake ABS system pump can have some air ....and old fluid.
Most shops don't do it or know about it. I haven't needed/done it yet myself, but will when I flush this spring. I have heard several different stories about an activation procedure in DIS I'm going to check it out in Rheingold as well. The other method is to go out after a normal flush & get hard into ABS several times, then come back and rebleed.
10-10-2016, 10:35 PM | #27 | |
Wotfun
Rep 14
I use ATE brake fluid and change it in he spring or summer, depending on when my first track weekend is scheduled. I fixed my H/T problem by adding a wood block on top of my brake pedal. It's actually two pieces that are a little over 1.5" thick. I used it at Summit Point (Shenandoah) this past weekend and it worked great - totally solved my H/T issue. During the offseason, I'm going to work on modifying it further to make it easier to left foot brake. |
10-12-2016, 06:51 AM | #28 | |
Rep 12,565
10-12-2016, 12:53 PM | #29 |
E86 M Coupe
265
Rep 402
I am using the ATE typ 200 DOT 4 fluid right now, and have not experience any brake fade or had the brake fluid boiling so far. Not too bad for a 1L bottle for $15. Will probably flush every 6 months/8000 miles I only need 1L to do a complete fresh flush/bleed on my Z4's brake system.
10-12-2016, 09:55 PM | #30 |
Rep 758
I use the ATE 200, but I do a system flush after every 3rd track day to keep relatively fresh fluid in the calipers. There's little circulation in the brake system and the fluid in the area of the calipers gets all the abuse and progressively breaks down which makes it more susceptible to boiling and brake fade.
Top Down 365
