      07-24-2013, 03:58 PM   #23
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
I just got this knob in my hand. if I'm going to switch the base, do I still have to separate the m5 knob and the boot?
If I separate them, do I have to break the white plastic ring inside the boot? reason being easier to change knob in the future; however, would the new m5 boot stay put without the plastic ring inside?
thanks and will try to attack this tonight.
FB Group-- > fb.com/groups/z4group
FB Page-- > fb.com/Skyermotorsport
      07-24-2013, 04:18 PM   #24
pungo
pungo's Avatar
I left the knob attached to the boot.
I have no idea if the boot will stay without the plastic ring since I left the ring intact.
      07-25-2013, 01:50 AM   #25
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
I just installed this and took it for a drive. Wow. Much better weight and this is what I've been looking for. A tad taller and heavier than the ZHP I had. Since I have the AS SSK, ZHP is a bit too short, OE is weightless, I have been on the hunt for a perfect shift knob.
Since I change my shift knob, daily vs track, I have to break the knob/boot combo. I tried my best to keep the white boot ring intact. The trick is to cut enough of a slit for the wires to be able to edge it out instead of breaking the top boot ring. So M5 boot is in and I can just pull it to change at my hearts desire.
Now, I have the M5 knob for daily and a taller metal knob for the track (don't care about too hot/cold since I wear gloves for track)
For those who cares, ZHP weights 152 grams and the M5 weights 169 grams.
      07-25-2013, 11:30 AM   #26
Gladius
Two Wheels or Four?
Gladius's Avatar
Drives: '18 Perf Edition m240i
Anyone know how much the M Performance knob weighs?
Current: '18 AW Performance Edition m240i
Gone: '15 Mineral Grey m235i || '07 Silver Grey M Coupe || '11 Space Grey 328i XDrive || '08 SparkG M3 || '01 LSB M3 || '01 TiAg 330ci
      07-26-2013, 05:43 AM   #27
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Which M performance knob? You will have to be more specific than that : )
      11-09-2013, 01:10 PM   #28
fdagen
Drives: 2006 Z4M Roadster
Guys,
Leatherz has done the comparison. Same hight and circumference. Slightly lighter than ZHP by a couple ounces.
Side-By-Side Comparison
Click for larger pictures
F10 M5 Shift Knob
Illuminated ZHP Shift Knob
Respectively:
Weight
6.0 ounces
6.3 ounces
Height
76mm
76mm
Circumference at widest point
164mm
164mm
