02-20-2014, 09:16 PM | #1 |
Rep 711
F30 M Performance brake kit retrofit
Anyone know of anyone that has retrofitted these to a Z4M or ZCP e46? I'm looking for a cheap way to get some better looking calipers. Not intending to track or needing more breaking power than I already have. Just disappointed in our ugly calipers.
|Evolve Airbox - Euro Headers - Strömung Exhaust - H&R Coils - 19" BBS CH-R| |
02-20-2014, 10:01 PM | #2 |
Rep 1,373
With a bit of modication to the "p0lar" rear caliper bracket and the rallyroad front bracket you can fit the BoxsterS/Cayman Brembo calipers using your existing ZCP/CSL rotors. At 4 wheel kit can be put together for around $1000-1400 depening on what you get the calipers for.
07 Z4 M Coupe AW/IR |
03-02-2014, 06:54 PM | #3 | |
Rep 441
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread |
03-02-2014, 09:54 PM | #4 |
Rep 1,373
Which rear brackets did you go with?
03-02-2014, 10:07 PM | #5 |
Rep 441
I have p0lar's brackets...he is a great sourest for everything to do with this upgrade. I also got all new high temp seals and dust boots from him as well
My Build Thread |
03-03-2014, 08:59 PM | #7 |
Rep 279
Probably PM him on m3forum.
06 Alpinweiss Z4M R Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake |
03-04-2014, 04:39 PM | #8 | |
Rep 1,373
The rear bracket does require a bit of grinding to make it fit. Other then that the whole system bolts up as it would on an E46. My brother got a chance to test the system on track one before the season was over and it worked great. More track testing to come this summer.
03-04-2014, 05:34 PM | #9 |
Rep 279
I have a set of almost new 928 GTS calipers.... I wonder if they could be made to fit? Hmmm
03-04-2014, 07:03 PM | #10 | ||
Rep 441
My Build Thread |
03-06-2014, 05:08 PM | #11 |
Rep 1,373
The bolt that connects the upper wishbone to the trailing arm contacts the bracket and it won't fit physically fit on without removal of a fair bit of material. A Dremel tool and some patience solved the problem. p0lar told me when I bought them to let him know how the fit was after I installed them. I got busy over the winter and forgot to shoot him an email. Knowing him once I tell him what's wrong he will have a fully engineered solution to the problem whipped up in an hour.
They sure do look good....
