      01-19-2012, 09:14 PM   #45
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
^ I think SA had the first s65 V8 into a e46 swap as well.
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      01-19-2012, 10:12 PM   #46
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Originally Posted by Roffle Waffle View Post
I gotta say... I didn't know South Africa was such a badass place for bimmer tuning
Definitely a huge WTF for me in the beginning lol..
      01-20-2012, 12:38 AM   #47
Z4mpora
South Africa
Drives: Z4m
Don't mess with our 3rd world country!! We might not have running water but we sure know how to tune beemers!!!!!
      01-20-2012, 03:30 AM   #48
Beedub
Originally Posted by flat_out View Post
Great work mate for sharing this again... left the GT3 standing, if it wasn't for the flat 6 haul in the background then i'd have sworn it was a normal overtake. I mean he gets on the gas before you and despite this your punch is instant..
Now come on S/C boys, lets see some footage showing speedo and rpm acceleration - i don't think i've seen one as yet on here (could be wrong though...)
you havent looked very hard!!!! i can think of at least 4 videos.....
      01-20-2012, 06:34 AM   #49
flat_out
Drives: Z4MC
You're probably right, there's been a few posted up one of which i beleive was yours. However, I don't think we've seen one giving as much insight as this one - by that i mean, In car with speedo visible as well as relative comparison against another car. I think all this would put things into context, no?
I'll have another search, but if you've beaten me to it, please share link
      01-20-2012, 06:54 AM   #50
flat_out
Drives: Z4MC
ok, that makes more sense and makes me feel better about having a less powerful kit. hahaha
There are 3 ways to increase traction. Number on is obvious -> move to a more sticky tire. There are several great tires in the extreme summer performance category. The other two are to run as wide of a tire as possible AND/OR to run as much sidewall as possible. Some say you don't need a very wide tire if you have enough sidewall flex... but you shouldn't run a tire thats much taller than stock, maybe just a single size taller sidewall....
In terms of width, you have to modify your rear fenders, and either buy 10.5" wheels and run 335mm wide rear, or modify your current wheels to be wider (adds positive offset that you have to fix with spacers)
Depends if you drive your car daily. If not, go straight to drag radials. If its a daily driver, go to 18" wheels with big sidewalls
Interesting, and quite technical for me .. I run 10" at the rear on 265/35/18's, previously with spacers but found these were catching the rear fender - Have you modified your fenders? if so would be good to see how this was done [pics please]
Are you saying to get max traction you need 335/30/18?
      01-20-2012, 07:36 AM   #51
A4RingedONE8T
Drives: Turbo ///M Roadster
No you don't need a 335 wtf, 265 or 275 is plenty to hook up what you need to, it's just a matter of tire selection and suspension setup. The bigger tire you put back there the more power you're losing to spin it. You'll never have traction in 1st, just ain't gonna happen unless your driving around on MT drag radials at 20psi, and that ain't happening either unless you can afford $600+ every 1500 miles. 2nd gear can be hit or miss, most likely get a small amount of spin and then you should be good. I have a 275/30/19 on the back of my Z3M Roadster, with 564whp/505wtq on 93 octane and the car weighing 2940lbs it will barely chirp in 2nd on shitty Hankook V12 Evo's. The Z4 rear suspension is far superior to that in my car, if mine can hook up on 275's, your's can as well. Tires are 50%, suspension is 50%. If someone says there's only 3 ways to increase traction and they all involve tire selection, I'm not so sure I'd pay much attention to what they are recommending. Your car is the first or one of the first to be running with boost, keep doing what you're doing. You'll find this stuff out for yourself in due time. If you don't have a proper fully adjustable coilover setup on that car, time to look into it. Don't worry about the tires for now, do some more research on that subject when it comes time to replace what you have.
-Shawn-
      01-20-2012, 07:59 AM   #52
Beedub
ok i get you, i think alot of people are very wary of public road racing..... i am for sure....
      01-20-2012, 10:01 AM   #53
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
-Shawn-
I DID miss the suspension portion, true. I was just talking about tire traction. In a straight line, I thought simpler suspensions hook up better (ex mustangs), and so do softer springs since they let more weight transfer to the rear.
I'm speaking from MY experience, and you're speaking from yours. In my experience, I had a Viper GTS, which ran 335mm PS2s in the back, and I could completely hook 1st gear in the summer. Thats why I'd like to run that size on my boosted z4m. But like you said, suspension plays into that so I could get a different result.
You didn't mention anything about sidewalls, and I honestly DO NOT KNOW if I'm better off with a 265/40/18 or a Viper spec 335mm in the back for better grip off the line and in 2nd gear. So I'll be quiet until I eventually try both options, and then report back here.
The z4 isn't great at laying down a lot of power in 1st gear on street tires, but I'd like to find the best solution I can. And no, that doesn't include softening up my suspension or softening up my chassis (I'm sure there are other ways, but I don't know them for this car)
I'm looking to get coilovers this season, what kind of general settings do you recommend?
      04-20-2012, 03:28 AM   #54
UberTaner
Drives: 2007 BMW Z4M Coupe
Hey Z4M Pora
I was at the track day at Kyalami earlier this year and saw your going round - I couldn't beleive how quick your car was, visually significantly faster than the GTR's and co. I had to run early that day so didn't get a chance to chat.
Anyway while at SAV this week, picking up my car from a checkup for the upcoming Swartkops track day i saw your car in the shop - man what a awesome car!
Sounds like you have worked out all the gremlins on the software side of things?
And are you going to be at Swartkops - would love to come and chat in person.
      04-20-2012, 04:12 AM   #55
Z4mpora
South Africa
Drives: Z4m
Originally Posted by UberTaner
Hey Z4M Pora
Hey bud. Thanks alot. Did you see us drag that gtr he had no chance!! Lol. It seems Sav has sorted the gremlins out. I don't think I will make swartkops. But come to midvaal on Sunday. We have set up a drag. Mclaren Mp4 vs my Z4m turbo!!! Will post video of it here too. We will definite hook up. Thanks again for comment on my Z
      04-20-2012, 06:07 AM   #56
UberTaner
The Mclaren is going to have to be something special to keep up with what i saw!
Will you be running full boost against it or 'stage 1 mode' at around 680bhp?
Woukd definitely be interested to come and watch but Sunday is looking pretty full, what time?
Sav also mentioned that you had a ACS exhaust on before the mod but you had sold it. What did you think of the exhaust? I ask because I might be looking to replace mine soon am currently leaning towards RE Diablo's but would like to hear the 21st April compilation video that the guys on this board are going to make first
      04-20-2012, 09:08 AM   #57
Beedub
ok how about some updated pics of this bad boy :-)
engine and exterior/ interior shots pleassssseee!!!
      04-21-2012, 01:11 AM   #58
The__J__Factor
Australia
88
Drives: ///M Coupe
Can't wait to see the race with the mclaren
135i N54 manual
      04-29-2012, 05:49 AM   #59
flat_out
Drives: Z4MC
.....i think alot of people are very wary of public road racing..... i am for sure....
I'd refer to it more as useful consumer advice/product testing...
      04-29-2012, 05:50 AM   #60
Beedub
lol....
