      12-24-2021, 02:09 PM   #1
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
CCV/PCV Not the Problem?
08 Z4 3.0si black cover. Replacing the diaphragm in the valve cover since I've been getting all sorts of issues, including tons of oil in the intake and lower DISA and running rich codes. Now I'm not sure if it is the CCV/PCV. I removed the cover on the diaphragm to do the "hack" with out replacing the valve cover but the diaphragm is only a little oily but otherwise in great shape, no tears or holes. Maybe this isn't my issue?
I did have too much crankcase pressure as well, difficult to remove oil cap, an oil leak at the valvetronic motor gasket when doing AutoX. Also looks like it went through the intake gaskets. DISA motors look fine, no broken flaps but covered in oil. I do smell fuel in the intake oil. Any other possible culprits? Thanks for any help!
      12-24-2021, 02:42 PM   #2
wdb
dances with roads
wdb's Avatar
4732
Ugh. Combustion pressure getting into the crankcase? (Warning: internet wild-a**ed guess.)
      12-24-2021, 04:02 PM   #3
Our03z4
God I hope not lol. Coolant does drop ever so little over time. Oil is always clean though.
wdb4732.00
      12-24-2021, 09:34 PM   #4
wdb
dances with roads
wdb's Avatar
4732
It’s not something I’ve ever heard of from the N52. Happy Holidays!
      12-26-2021, 09:50 AM   #5
Our03z4
Bump
      12-26-2021, 12:55 PM   #6
Steeler
Steeler's Avatar
2429
Any codes?
Are you seeing higher than normal oil consumption??
