      08-11-2020, 09:14 AM   #67
RossBMWZseries
Originally Posted by F360C View Post
Ohhhh looks sexy! If you dont like the TMS logo there is a guy on ebay from PA that sells exact replica M Power stickers for the box.
Yeah he did almost loose it.. he is damm lucky!
I’m definitely removing the TMS logo, am just debating whether to leave it all blank or put some sort of ///M decals, which may just be too much considering the roundel on the radiator cover and M badge on the engine cover are both already there.
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
      08-22-2020, 12:45 PM   #68
SLC801
Drives: LSB Z4MC
Looks like this is now sold out and unavailable for Turner? Any insight anyone?
      08-24-2020, 05:52 AM   #69
Alaberti
And yet
Alaberti's Avatar
Drives: Jaguar F-Type V6 S BDE
I suspect it's sold out and unavailable for Turner
      08-24-2020, 08:49 AM   #70
David70
If you want the most accurate answer I would just call them.
      08-24-2020, 02:43 PM   #71
maupineda
Drives: E86 Z4MC
^^ There is a very extensive thread about this product over at NAM3 forum, and there were a few design issues that caused trouble to many, and I understand the design is being revised, so maybe that has to do with the availability of their CSL box.
      10-04-2020, 12:04 AM   #72
paskov
Drives: E46
This is not street legal in California, right? Or, is it?
      10-04-2020, 11:34 AM   #73
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Everything is illegal in California
Texaz3194.50
      10-29-2020, 11:08 AM   #74
Texaz3
Drives: Z3MC Z4MC E36M E46M E93M E39M
What kind of tune does this require, and where can I get that done? I'm assuming this won't run on stock ECU tune, since MAF is deleted. Does anybody do these remotely?
      10-29-2020, 03:06 PM   #75
1stw0rldpr0blems
Drives: 2006 Z4MC
You would need to run it on an Alpha-N tune. There are a couple tuners that can do that for you, but EPIC Motorsports in South FL is well known and can do the tune remotely. You would need to schedule dyno time at a facility somewhere, and he can tune remotely on a laptop through wifi. I do not have a carbon intake yet, but I do have an EPIC tune and I don't have any negative comments about his tune or service.
      10-29-2020, 04:25 PM   #76
Steeler
Steeler's Avatar
2429
Severn Tuning does remote tunes
https://www.facebook.com/11460346027...0614480343687/
      01-29-2022, 09:53 PM   #77
RossBMWZseries
Originally Posted by DRedman45 View Post
I got everything to install the airbox before my buddy had a dyno opening so I went ahead got started installing the box.
I have run into two minor issues.
The stock crankcase vent hose doesn't reach so I'll be extending it with rubber hose which is my only hold up currently. The other option is buying a csl crankcase vent tube and removing the crankcase side connector to splice in the stock connector. This is normal but turner doesn't list anything as part of their kit so I assumed that the factory hose would work.
My other issue was the oil drain bung on the airbox had apparently come off in transport. I used a bit of jb weld to secure it.
Otherwise the install has been smooth sailing and fitment is spot on.
I'll get a few more pictures when I get finished up
Any updates on that issue? Any air leaks? Has it held on since you used the JB weld? I'm barely getting around to install my airbox and I broke the similar bung (bigger in size) underneath the airbox. It's the bung located near the power steering reservoir where the hose connects. The hose barely reaches the bung to be able to connect properly, but after a few seconds, the pressure broke the bung, or I should say the adhesive came off. Any ideas if I should JB weld this as well or any other solution to this issue is greatly appreciated. TIA!
      02-02-2022, 09:28 AM   #78
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
This issue feels unacceptable for a $1500 part, any communication from Turner on improving the design?
      02-04-2022, 09:21 AM   #79
RossBMWZseries
I haven't contacted the company myself and I really don't know if others have. I bought the airbox sometime last year so I'm just gonna try to put it back together using some sort of epoxy.
