02-14-2022, 02:44 PM | #1 |
Rep 2
2008 Z4 3.0i 2E84 Water pump
Hello there, I have a 2008 Z4 with the N52 with ~75k and am having issues with the water pump not turning on. I've swapped it out twice now so I can't believe it is a factory defective pump.
I was able to pull two codes for the engine with my friends scanner. 2E84- Electric water pump communication 2E7C- Bit- serial Data Interface, Signal I am wondering if maybe there is a bad relay or fuse for the water pump? does anyone know where such things would be? If anyone has had similar issues I would appreciate any suggestions. Thanks! |
02-20-2022, 11:12 AM | #2 |
Rep 18,806
The E90 Post Forum has a lot of threads on this code issue.
This one may help. https://www.e90post.com/forums/showthread.php?t=1899426
