Go Back   ZPOST > Marketplace > Sponsors Classifieds
      11-30-2012, 01:30 PM   #1
ApexWheels
ApexWheels's Avatar
1438
Drives: M3
► APEX | EC-7 End of Year Group Buy
Closed
      12-03-2012, 06:04 PM   #2
ApexWheels
ApexWheels's Avatar
1438
Drives: M3
This is a great opportunity for the track guys out there to get great savings on 18x9.5" ET35 square set ups for their Z4's!
18x9.5" ET35 front wheel with a 265/35/18 and an 18x9.5" ET22 in the rear with a 265/35/18. The 18x9.5" ET35 square set up will offer a very similar look when using a 12mm rear wheel spacer and the ability to rotate tires!
      12-04-2012, 08:19 PM   #3
mike519
mike519's Avatar
Drives: 2018 M240i
Would have loved to jump on this group buy but neither the front or rear sizes that you recommended to me in the wheels and tires forum are in the list here.
      12-04-2012, 08:22 PM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Looks like odd size stock clearance.
      12-04-2012, 09:34 PM   #5
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
What sizes can you recommend for a Z4M on a stock suspension?
      12-05-2012, 11:17 AM   #6
ApexWheels
ApexWheels's Avatar
1438
Drives: M3
The wheels out of this group buy that apply to the Z4M section are the 18x9.5" ET35 square track set up and 18x9" ET31 wheels. The 18x9.5" ET35 square track set up does require camber plates in the front. This is because of the width and tire application for that 18x9.5" ET35 front wheel are much wider than stock so negative camber is needed to pull the top of the wheel and tire under the fender. The grip gains on the track and auto x'ing the car far outweigh the added cost of camber plates. Look for more group buys later this winter in January and February that will provide more direct wheel fitments for your cars.
      12-05-2012, 12:12 PM   #7
strokeoluck
Drives: 2007 BMW Z4 M roadster
So if I have a stock Z4M, and I want stock wheels in silver, can I order from this deal? I just want to take them into my local tire shop and have them out them on...no camber, no filler pieces, etc. I get very confused when I read about all of these Apex sizes. Love the wheels, but since this isn't a primary focus of attention a lot of it is fuzzy.
      12-05-2012, 12:49 PM   #8
ApexWheels
ApexWheels's Avatar
1438
Drives: M3
With this EC-7 group buy there are no direct fitment wheels for your Z4M. We will be holding a couple more rounds of group buys this winter in January and February which will include much more popular sizes that will be direct fitments for your Z4M.
      12-06-2012, 06:30 PM   #9
ApexWheels
ApexWheels's Avatar
1438
Drives: M3
Here is the updated feeler list! Keep Spreading the word since we are half way there to the 2nd tier discounted pricing!
Username / Size / Finish / Forum
1. Vigorous / 18x9.0” ET31, 18x10.0” ET33 / Anthracite / E90post
2. Rcsummers / 18x10" et33 / Anthracite/ E46Fanatics
3. EYEHAVEYOU / 18x9.5” ET35 / Race Silver / M3Forum
4. ScreamingChicken / 18x9.0” ET31, 18x9.5” ET35 / Anthracite / E90post
5. jjellyneck / 18x9.0” ET31, 18x9.5” ET35 / Race Silver / E90post
6. eriktufa / 18x9” ET31, 18x10” ET33 / Race Silver / E90post
      12-06-2012, 08:10 PM   #10
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
Will the 18x9.5” ET43 have enough inner clearance mounted up front without a spacer ?
I'm going to guess no
      12-07-2012, 11:30 AM   #11
ApexWheels
ApexWheels's Avatar
1438
Drives: M3
The 18x9.5" ET43 will need a 15mm wheel spacer to clear the Z4's front strut. You may be able to sneak by with a 12mm wheel spacer depending on the size tire that you use and your current suspension. If you have coilovers installed with a Linear race spring that is 6" or shorter with the spring perch above the tire it could be possible but a safe bet would the 15mm spacer. Regardless the 18x9.5" ET43 will need camber plates to fit and you would be much better off with our 18x9.5" ET35 because there is no need for spacers with the ET35's lower offset.
      12-10-2012, 02:49 PM   #12
ApexWheels
ApexWheels's Avatar
1438
Drives: M3
The feeler list has been updated. 2 more wheel sets and we will make it to the $50 discount with free shipping*!
7. Camdinans3 / 18x9 et31 / race silver / M3forum
8. jcraigc / 18x9.5” ET35 / Anthracite / M3Forum
9. chrisl91/18x9.0” ET31, 18x9.5” ET35 / Anthracite / E90post
      12-13-2012, 12:23 PM   #13
ApexWheels
ApexWheels's Avatar
1438
Drives: M3
Updated feeler list below! We have reached the next tier of $50 off retail in addition to the free shipping* you are already receiving! This group buy will officially open up on our website on Friday, December 14th!
7. Camdinans3 / 18x9 et31 / race silver / m3forum
9. chrisl91 / 18x9.0” ET31, 18x9.5” ET35 / Anthracite / E90post
10. andrew_b / 18x9.0” ET31/ Race Silver / E90post
11. b4ever / 18x9.0” ET31, 18x10” ET33 / Race Silver / E90post
12. Ohnein / 18x9.0” ET31 / Race Silver / E90post
13. tigermack / 18x9” ET31, 18x10” ET33 / Anthracite / E90post
      12-14-2012, 02:06 PM   #14
ApexWheels
ApexWheels's Avatar
1438
Drives: M3
Group buys are officially open! Remember to keep spreading the word as much as possible for potentially more savings! If possible put the below link in your signature and share it on facebook. Thank you guys!
Click here to join the Group Buy!
Here is the current list!
1. Vigorous / 18x9.0" ET31, 18x10.0" ET33 / Anthracite / E90post
3. EYEHAVEYOU / 18x9.5" ET35 / Race Silver / M3Forum
4. ScreamingChicken / 18x9.0" ET31, 18x9.5" ET35 / Anthracite / E90post
5. jjellyneck / 18x9.0" ET31, 18x9.5" ET35 / Race Silver / E90post
6. eriktufa / 18x9" ET31, 18x10" ET33 / Race Silver / E90post
8. jcraigc / 18x9.5" ET35 / Anthracite / M3Forum
9. chrisl91 / 18x9.0" ET31, 18x9.5" ET35 / Anthracite / E90post
10. andrew_b / 18x9.0" ET31/ Race Silver / E90post
11. b4ever / 18x9.0" ET31, 18x10" ET33 / Race Silver / E90post
12. Ohnein / 18x9.0" ET31 / Race Silver / E90post
13. tigermack / 18x9" ET31, 18x10" ET33 / Anthracite / E90post
      12-17-2012, 07:02 PM   #15
ApexWheels
ApexWheels's Avatar
1438
Drives: M3
Remember the group buy is officially open until Friday December 21st. The sooner you guys pay the deeper the discount level will be because everyone will see that there are people actually in the group buy. There is no reward for paying late, everyone will receive the same pricing tier regardless if they pay today or December 21st. This is not an auction and there are no rewards for paying late so jump on in as soon as you can!
      12-18-2012, 06:49 PM   #16
ApexWheels
ApexWheels's Avatar
1438
Drives: M3
Remember for those that were interested and on the Feeler list the group buy officially closes on Friday, December 21st. There is no benefit to joining the group buy later but there is a benefit to joining earlier since more people will see that you have joined.
Official Paid List
1. Charles M.
2. Kevin R.
      12-19-2012, 06:27 PM   #17
ApexWheels
ApexWheels's Avatar
1438
Drives: M3
Remember to jump in the group buy while there is still time left, until Friday December 21. We have people from the feeler list who still have not paid!
Official Paid List
1. Charles M.
2. Kevin R.
3. Arthur A.
      12-20-2012, 06:56 PM   #18
ApexWheels
ApexWheels's Avatar
1438
Drives: M3
Remember tomorrow, December 21st @ 11:59PM PST, is the very last day to join the group buy! We have people from the feeler list who still have not paid yet! The more participants we have in this group buy, the lower the price will be for everybody!
Race Silver 18x9.5" ET35 EC-7's with a 12mm rear wheel spacer
Official Paid List
1. Charles M.
2. Kevin R.
3. Arthur A.
      12-21-2012, 06:17 PM   #19
ApexWheels
ApexWheels's Avatar
1438
Drives: M3
Today is the last day to get in this group buy! Remember to sign up by 11:59 PM PST for $50 off your total retail cost and either free shipping in the continental U.S. 48 or discounted international shipping. Please email us directly for international orders.
Official Paid List
1. Charles M.
2. Kevin R.
3. Arthur A.
4. Tyler C.
5. Brandon H.
      12-27-2012, 04:00 PM   #20
Expert@ApexWheels
Expert@ApexWheels's Avatar
3546
Drives: M3
Thank you for everybody that have participated in the group buy this time! Even though we did not hit the amount of wheels that was anticipated by the feeler, APEX has decided to keep the discount tier that we previously reached with the interest in spirit of the holidays! That means that you will be receiving $50 off with free shipping* for the EC-7s!
Official Paid List
1. Charles M.
2. Kevin R.
3. Arthur A.
4. Tyler C.
5. Brandon H.
6. Ricky C.
The staff at APEX would like to wish everyone happy holidays, and a happy new year!
