      10-04-2015, 01:37 AM   #1
mpathic
Drives: Z4 MCoupe,3.0Si R,E61 535xiT
Wanted: Z4 M front strut, any condition is fine.
Do you have a stock front strut? Worn out or leaky is fine because I need only the tube. I'm working out a mod, maybe just making a custom shim or spacer, to use E36 Koni strut inserts in the E85/6 M strut tubes.
Currently there are no Koni options for E85/6 M front struts.
tia,
Barry
And you may ask yourself, "Where is that large automobile?"
      10-04-2015, 09:28 AM   #2
unluky
unluky's Avatar
7528
I have a front strut from a 2004 3.0i with M sport. It is shot, but yours if it helps.
      10-04-2015, 04:41 PM   #3
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
The M Sport struts are Z4 struts with a bit stiffer damping and are in a housing similar to what the E46 uses. The Z4M uses a strut housing similar to the E36M3. The attachment to the spindle casting is completely different between the two.
Top Down 365
      10-12-2015, 04:39 PM   #4
mpathic
Found a pair, no longer seeking.
      10-12-2015, 04:55 PM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
Originally Posted by mpathic View Post
... I'm working out a mod, maybe just making a custom shim or spacer, to use E36 Koni strut inserts in the E85/6 M strut tubes. ...
And you may tell yourself
MY GOD!...WHAT HAVE I DONE?
      10-12-2015, 05:14 PM   #6
Steeler
Steeler's Avatar
2429
Am I right
Am I wrong
