      10-01-2015, 11:05 PM   #1
DeutschRennfahrer
DeutschRennfahrer's Avatar
39
Drives: 2006 Z4 3.0i - Saphire Black
Replacing Halo Ring bulbs - LED options?
So one of my halo ring parking lights went out and is throwing a warning light on the dash. I'd really like to replace all of them with LED bulbs for better brightness and longer life. I found these on CarID, but I am skeptical that they will fit.
Has anyone tried this? What would you recommend?
      10-02-2015, 08:21 AM   #2
chickdr
Drives: 2006 M Roadster
Unfortunately there are no options that work without recoding the car to not thrown a bulb out code. There are many threads on the subject.
      10-02-2015, 11:56 AM   #3
m3power13
m3power13's Avatar
111
Drives: E92 M3 Stripper
That is really a bummer if true!
Surely there is a solution. Most other auto/motorcycle applications just need a resistor to prevent a code from being thrown. The 2008 E92 cars have no problem running LED bulbs for the angel eyes.
E92 M3 - Alpine White - Carbon Roof - 6 SPD - Speed Cloth - No NAV/EDC - Meisterschaft - Signature Forged
      10-02-2015, 03:26 PM   #4
chickdr
You can use an LED replacement but it really isn't much brighter from the photos I have seen. It also throws the bulb out code. It is too bad nobody had developed an error free halo replacement but alas they have not. There are also no LED options for the front turn signal bulbs in the hockey sticks...
      10-02-2015, 04:21 PM   #5
wdb
dances with roads
wdb's Avatar
4722
Throws a code, really? That piques my electrical interest. It may be happening because LEDs are diodes. Has anyone tried reversing the mounting orientation?
Links to earlier discussions gratefully accepted.
      10-02-2015, 04:35 PM   #6
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
LEDs draw much less current than standard light bulb, thus causing the system check to think there's an "open circuit" as in burned light bulb - therefore throwing a light out code. You can code your car to not check for bulb out.
      10-03-2015, 06:13 PM   #7
DeutschRennfahrer
39
How hard would it be to code out the warning light? I'm planning on having a performance tune done on my car later on, so perhaps it could be coded out then?
      10-04-2015, 01:18 PM   #8
wdb
dances with roads
wdb's Avatar
4722
Ah, so the warning light is there when the lights are on. I guess you could put a resistor in line to force it draw more current, that way you would keep the bulb check functionality.
      10-04-2015, 02:49 PM   #9
pungo
pungo's Avatar
Adding a resistor would not "keep the bulb check functionality", if the bulb did burn out it would not cause an error since the LSZ would measure the resistor resistance and think the bulb is ok. It's way easier to just code the LSZ to not check the halos then trying to add resistors.
BTW #1, the resistor would be installed in parallel not in line.
BTW #2, the LSZ checks the bulbs when they're not on as well when they're on, so disable both cold and hot checks in the coding.
      10-05-2015, 05:11 PM   #10
wdb
dances with roads
wdb's Avatar
4722
True but LED should last an eon so there is less risk. But now that you say that you can code it to just not check the halos I agree, that's the best course of action.
See, that's what happens when I put away my electrical hat for so long.
Now to figure out how I program an LSZ...
...right after I figure what 'LSZ' stands for.
      10-05-2015, 05:39 PM   #11
StickMon
StickMon's Avatar
Drives: 2006 MR
Those are the wrong type for the Halos. You need BA9s.
Here's what I have.
They have the potential to be brighter, but when you stick them in, the CREEs on the side go a little past the halo ring, so they're not directly lit.
No dimmer though, and whiter.
Had to code out the bulb check.
      10-09-2015, 02:01 PM   #12
bmwZ
bmwZ's Avatar
Norway
202
Drives: Z4 35i ESS
On my old E85 I used a bulb with built in resistor. It was also quite bright... No codes, but can't remember the type of bulb..
      10-09-2015, 03:32 PM   #13
wdb
dances with roads
wdb's Avatar
4722
I'm sorry but that is insufficient information.
Seriously, if there is any way for you to recall what you used, I for one would be ecstatic.
      10-09-2015, 03:58 PM   #14
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
Looks pretty damn good, in for info as well
      10-09-2015, 04:17 PM   #15
pungo
pungo's Avatar
Not to say those bulbs don't look nice in this picture, but I'm pretty sure those bulbs would not be very bright in broad daylight. The picture was probably taken with a long exposure in a semi dark area making the bulbs look brighter than they really are.
      10-09-2015, 07:49 PM   #16
Mirko
Mirko's Avatar
Do you think this would work?
http://www.aliexpress.com/item/2Pcs-...422697186.html
      10-09-2015, 08:53 PM   #17
AmmarYasirA
Ammar
AmmarYasirA's Avatar
Drives: a lot
When I bought my MRoadster, the very first thing I needed to do was to replace one of the halo bulbs that had gone out. I already knew that I wanted a bright LED option and so I started searching...and searching... And searching. From buying atleast 4 pairs of bulbs online in the past year, the best option is to switch the entire base of the bulb. The Ba9s base that is used for the halo bulb doesnt have enough (good) LED options.
I have a set of LED Ba9s in my headlights but:
-they're not bright enough
-the blue tint in the headlights for the Halo makes them too blue
-for $30 its a waste of money
-they dont match the xenons in my car
Ive been so busy that I've (maybe) taken the car out about 3 times in the past 4 months. But the moment I find some time ill get around to switching the base of the bulb and putting in a proper LED bulb in there to make it look right.
A few months back another member switched the base of the bulb to install a brighter LED bulb and he also had a full DIY for it as well. I would recommend anyone that wants a brighter halo bulb for their car to follow that route. Trust me, its easier that way.
2018 F150 Platinum - Black/Black - Leveled on 34's - DD
      10-09-2015, 09:12 PM   #18
m3power13
m3power13's Avatar
111
Have a link to that DIY?
      10-09-2015, 09:20 PM   #19
chickdr
Not understanding what you mean by "switch the base of the bulb"????
      10-12-2015, 02:31 PM   #20
StickMon
StickMon's Avatar
Drives: 2006 MR
There's a thread around where somebody hacked up the plastic holder and put in BAU15s (1157, 7507, etc.) socket.
Worked out well IIRC.
I've been pondering hacking up some spares I have to back the CREE up about 1/4" so the LEDs line up with the halo ring.
I've been pondering a lot of things that I'll never get around to.
      10-14-2015, 11:52 PM   #21
cogriff
cogriff's Avatar
Drives: 2006 Z4MC
2014 Audi  [0.00]
2006 BMW Z4MC  [9.00]
1977 Honda CB750K  [0.00]
2007 Kawasaki ZX6-R  [0.00]
Not sure if the thread you're referring to is mine but I did this. here is the link:
http://www.zpost.com/forums/showthread.php?t=970661
hope it can help someone.
      10-15-2015, 12:55 PM   #22
StickMon
StickMon's Avatar
Drives: 2006 MR
^Yep, that was it.
Thanks!
