      07-02-2015, 01:35 PM   #1
Spaceman Spiff
Drives: R8, 996 C2, Z4MR (sold)
Z4M ambient temp sensor
Does anyone know where the ambient air temp sensor is located in the MR? I know for non-Ms it's in the lower section of the driver side wheel arch, but since that area is blocked by the brake duct in the M, I was wondering if the sensor would be in a more accessible place. I tried removing the plastic panel behind the air duct but it seems connected to the duct itself and wouldn't budge.
Hopefully replacing the sensor isn't a bumper-off job
      07-02-2015, 02:13 PM   #2
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
It's on the bottom of the left fang.
      07-02-2015, 02:15 PM   #3
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Yes it's a bumper off job.
It's on the lower left side.
      07-02-2015, 02:18 PM   #4
Daemonblitz
Commander
221
2008 BMW M5  [9.50]
Honestly, after having my bumper off so many times, I realized that it's a very straight forward as long as you learn how to unclip the corners off properly without breaking the clips every time.
      07-02-2015, 02:20 PM   #5
Spaceman Spiff
Thanks guys!
They should have attached it on the outside, underneath the bumper. :So much work to just change a faulty sensor
      07-03-2015, 11:59 PM   #6
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
deamon, mind sharing your secrets of how NOT TO break the clips ill be needing to do this soon myself..
Powered by
      07-04-2015, 01:32 AM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
I've done it a couple of times without breaking the clips.
You have to work your fingers in there and try and push the sides out with straight and even pressure.
Doesn't break the clips, but man does it hurt your fingers.
      07-07-2015, 10:37 AM   #8
Daemonblitz
Commander
221
2008 BMW M5  [9.50]
Originally Posted by Vanne View Post
daemon, mind sharing your secrets of how NOT TO break the clips ill be needing to do this soon myself..
When you initially pull the corners of the bumper out you have to be very careful with the top-most rivet hole for the fender liner. If you look closely you will see that the rivet doesn't just go through the liner and bumper but also through that bumper clip, so you have to squeeze your fingers between the clip and bumper at the back/top and so you're only pulling on the bumper and not the clip as well. Hopefully that makes sense.
      07-08-2015, 04:09 AM   #9
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Will have to report back after giving it a go.. The guys
      07-09-2015, 08:41 PM   #10
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I use plastic trim removal tools, much easier on the fingers
      07-10-2015, 02:06 PM   #11
StickMon
StickMon's Avatar
Drives: 2006 MR
Yea. I bought the Griot's Garage set later.
Used them a lot to tear apart my trucks and pull the door cards on the Z.
Luckily haven't had to pull the bumper since I bought them.
      09-24-2015, 03:55 PM   #12
Spaceman Spiff
FYI I finally got around to doing it, and the way to go is by removing the wheel arch liner. Seems much easier than removing the bumper, and the whole thing took about 15-20 minutes. Unfortunately I didn't have the presence of mind to take photos but it's fairly straight forward.
