      12-13-2023, 08:57 AM   #1
EintrachtAdler
Drives: E85
E85 3.0si manual transmission and diff fluid change: do I HAVE to get new plugs?
I’ve been doing my research to prepare for this job and cannot find anything definitive. I have 2 unopened Redline MTL bottles and 2 unopened Redline diff fluid bottles from a prior car that I want to swap in but would love to not buy the drain plugs if I don’t have to. They’re about $20 per plug right now. What is the consensus on reusing the plugs? I know the ones on the trans have the green seal. Could I avoid any issues with changing the plugs if I just suck the oil out of the fill plug and fill from there so the drain plug was never touched? And for the diff, do the plugs there even have any gaskets that would require new plugs?
For anyone that has reused the plugs, have you had any issues or leaks?
Thanks!
      12-13-2023, 09:48 AM   #2
pungo
pungo's Avatar
The worst thing you could do is suck the oil out of the trans through the fill plug since you want to flush stuff in the bottom of the trans out by draining from the drain plug .
Plus, do it when it's hot so the fluid is thinner and flows out better.
I've reused the plugs in a pinch without issue, though I usually change them. The seal gets flattened over time as well as they're soft so unless it comes out easily, the hex may get a little worn.
My records show they were ~$10 for OEM plugs a few years back, you don't have to get them from the dealer.
If you reuse them, use some brake clean to clean the seal, then apply a thin film of RTV over the seal and let it dry while changing the fluid.
      12-14-2023, 08:32 AM   #3
bosstones
Drives: o_0
Not sure which version or transmission type you have but a quick, arbitrary look shows anywhere from $6 to $19 for a drain plug for a 3.0si and M, respectively.
For $20, I'd change it for the gasket. Overpriced, perhaps, but $20? That is cheap insurance to know I have a good seal. It's up to you if you want try to re-use or make up your own solution. For << $20, that's a no-brainer.
Like Pungo indicated, why would you not drain the crap out of the pan? Unless you you need the added....viscosity.
      12-14-2023, 04:50 PM   #4
wdb
dances with roads
wdb's Avatar
4732
I didn't like Redline trans fluid in my Z4MC. I don't see any reason not to replace at least the drain plugs; you only do the job once every 30K miles or so, seems silly not to do it well.
      12-15-2023, 11:04 AM   #5
belcom
belcom's Avatar
Drives: '18 540i, '06 Z4si, '07 Z4MC
Why? What happened?
      12-15-2023, 11:40 AM   #6
3798j
3798j's Avatar
11427
Drives: E86 3.0si
'55 Ford F100  [0.00]
'08 Z4 3.0SI  [8.50]
'66 Triumph TR4A  [0.00]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
'68 Triumph GT6  [0.00]
'19 VW Golf "R ...  [0.00]
RedlineOils isn't recommending their MTL. Their website lists D4 ATF for Z4 6spd manuals ...(D4 ATF for the M).
      12-15-2023, 12:37 PM   #7
wdb
dances with roads
wdb's Avatar
4732
Originally Posted by belcom View Post
Why? What happened?
Yep, and that's what my car had in it from the PO. It didn't shift well cold and the infamous 3-2 downshift was nasty. I went with Royal Purple and both improved.
      12-15-2023, 01:51 PM   #8
belcom
belcom's Avatar
I got purple in the transmission as well. Seems it works well for me too. But what do you think about Red Line 75w140 gear oil for the M diff? Got purple in there now but its been a while and will be changing diff fluid in spring time. Already have Red Line on the shelf for that based on a recommendation from a buddy.
      12-15-2023, 04:25 PM   #9
wdb
dances with roads
wdb's Avatar
4732
I used BMW oil in the differential. Wanted to treat the LSD properly.
      12-16-2023, 01:46 AM   #10
GuidoK
GuidoK's Avatar
10871
Drives: Z4 3.0i ESS TS2+
Thanks!
I've reused the plugs on both the gearbox and the different (multiple times on that one even) and had no issues.
Efthreeoh17318.00
      12-16-2023, 01:47 AM   #11
GuidoK
GuidoK's Avatar
10871
But BMW doesn't make oil 😉
      12-16-2023, 03:02 PM   #12
tomjonesBT33
tomjonesBT33's Avatar
Drives: 2006 Z4 M Roadster
I agree that it’s best to spend the money and change the plugs. Cheap insurance.
I use Redline in both my Z4MR trans and rear diff and have been very happy with the results. To each their own I suppose
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic
2012 X5 M - Monte Carlo Blue Metallic
2017 X1 xDrive28i - Alpine White
      12-17-2023, 08:55 AM   #13
cbpip
cbpip's Avatar
151
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [0.00]
Plugs are relatively inexpensive, why not replace. Reusable absolutely.
Using the Ford Fluid, works great allows synchros to mesh as they should. Tried the Redline stuff, too thin synchros didn't like it. Not a fan of RP products due to inaccurate sheer strengths.
https://www.amazon.com/gp/aw/d/B000N...b_b_asin_title
      12-25-2023, 02:35 PM   #14
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
Over one million miles driving 5 different BMWs 400K, 250K, 197K, 135K, and 120K. Multiple diff and trans changes on each. I've never replaced a drain or fill plug. Waste of money and internet myth they need to be replaced.
My advice is make sure you have the tools on hand to reach and can remove the fill plug FIRST before opening the drain plug.
