      11-26-2023, 05:15 PM   #1
Zipper06
Drives: Z4
Question Chewed wires
Got sensor error code, went to replace it and found a few missing wires. Rabbit or squirrel I'm guessing from leaving car outside this summer.
Doesn't look like enough for wire left to repair on the lower coolant sensor plug, and not even sure where the cable went from the right side panel stub left. Attaching pictures. Can I get a new harness plug? Couldn't find anything on realoem.
Suggestions? I'm worried there may be other wires damaged I'm not seeing.
Actually, looking again, do I just need to connect the coolant sensor to that right side stub and simply repair the upper wires together? That upper section is pretty tight, maybe it was a rat.
      11-27-2023, 06:37 PM   #2
Zipper06
Drives: Z4
Found plug here.. hopefully this is all I'll need..
https://www.partsgeek.com/catalog/20...connector.html
      12-02-2023, 02:39 PM   #3
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
I had a rat chew the same exact harness in the same place on the body side of the harness at the plastic shroud side. The code I got was 2EEA, which states outlet temperature probe. To get enough wire to repair I had to remove all of that bundle of tape to expose more wire. You'll have to do the same as I did. When I repair chewed wires I butt-joint the wires together (stick the strands into each other then solder the joint. I put heat shrink on the wire before connecting the wire ends together, then once soldered I slide the heat shrink over and shrink it with a heat gun (see link to one of my posts on E90Post). I think the part you specify plugs into the temp probe in the lower radiator hose. I think you also need to repair the harness on the "Sensor f. AUC" (P/N 64116917001) which is the chewed blue, yellow, and brown wires in the top pic. That sensor controls the air flap in the HVAC system when you have the auto-recirculate button activated.
https://www.e90post.com/forums/showt...2#post30535522
