      12-08-2017, 11:55 AM   #1
mustang Al
Drives: 07 Z4 M coupe
battery replacement in the key fob
Is it possible to replace the battery in the Key remote fob?
      12-09-2017, 07:15 AM   #2
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Check this out, mustang Al.
https://www.bmwgm5.com/bmwgm5/kr.htm
Salty
      12-28-2017, 06:18 PM   #3
coh661
Drives: 2007 Z4M Coupe
2007 Z4 M COUPE  [8.00]
Looks pretty doable if your problem is indeed your battery. Involves cutting open the key housing. Here's also a link to the battery i think you need. Pretty sure that's the one but not 100% sure.
DIY
Battery
https://rover.ebay.com/rover/0/0/0?m...2F292295276711
      12-31-2017, 06:26 PM   #4
apexhittinbull
Drives: E85 M
I replaced the battery in mine.
I bought a rechargeable Panasonic battery and found out that contact tabs from key fob will not ever solder onto the battery.
So you have to make sure you buy the battery with bmw key specific tabs already stamped.
https://www.ebay.com/itm/Brand-New-P...72.m2749.l2649
      01-21-2018, 02:26 PM   #5
Tom Broderick
Drives: 2003 2.5 Z4
New member here, I am recharging my keys when not in use on my toothbrush chàrger, seems to work.
      01-25-2018, 09:41 PM   #6
saintex
Drives: Z4MC BSM E92 335xDrive BSM
whoa
pics of the setup plz
      01-26-2018, 02:11 AM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
Just don't accidentally brush your teeth with your key.
      01-28-2018, 10:29 AM   #8
SaltyNC
SaltyNC's Avatar
370
I never thought about that. I usually just swap keys periodically. We have Sonicare toothbrushes. Do you know if it will charge if the toothbrush is charging, or it is one at a time? And how close does it have to be?
Thanks for the cool tip.
Salty
      01-28-2018, 10:30 AM   #9
SaltyNC
SaltyNC's Avatar
370
Salty
      02-13-2018, 07:53 PM   #10
rsutoratosu
Drives: Z4 3.0i
wait whattttt.. is it induction charging like cell phone or you actually need sonic care.. i have first original sonic care series.. just drop it on ?
-Roranji
      02-13-2018, 07:54 PM   #11
rsutoratosu
Drives: Z4 3.0i
lol... found it
-Roranji
ried791.50
      02-14-2018, 10:48 AM   #12
coh661
Originally Posted by rsutoratosu View Post
lol... found it
Genius!
