      11-08-2008, 11:36 AM   #1
takedown8
takedown8's Avatar
Drives: 2005 BMW Z4 3.0i
How to connect these cables?
This is a shot in the dark, but hopefully some of you with electrical skills will be able to help me.
I have 4 of these cables (small, internal audio/power cables) that I want to connect end to end to make one long cable. What is the easiest way to do that? Are there male-male bare pins that will connect them or a male-male cable or do I have to solder them together? (I'd prefer not since I don't know how to do that).
Thanks in advance!
      11-08-2008, 07:25 PM   #2
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
If you dont need to separate the 4 segments later on the easiest way might be to cut the ends off and use butt connectors, yes they are called butt connectors and they look like this.
Insert stripped end of each wire into one of the two sides, crimp, voila. No soldering required.
      11-08-2008, 08:22 PM   #3
04scoobysti
Drives: 06 M Coupe
or for a more permanent install solder and heat shrink. I find those butt connectors fail more times than not.
      11-08-2008, 08:52 PM   #4
BimmerZealot
He said above he didn't want to solder because he doesn't know how. Of course he can learn and its simple but butt connectors are the non-soldering option requested. At my work we wire up 10-20 headlights a day with butt connectors and I have yet to see one come back with a failed connector. Use the right gauge rating, crimp properly, no problems.
      11-09-2008, 10:34 AM   #5
takedown8
takedown8's Avatar
Thanks for the responses, guys. I guess I'll have to bite the bullet and have the wire soldered.
