      07-24-2016, 07:32 PM   #1
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
recomendation for fcab bushing press?
I'm going to be installing powerflex fcab's soon. Any recommendations on tools to press the bushings in/out of the lollipops?
Anyone have experience with these?
http://www.ebay.com/itm/27pc-Tool-Se...-/252424169860
http://www.ebay.com/itm/MIS-BMW-FCAB...-/281900588564
Thanks
      07-24-2016, 11:37 PM   #2
N55_Mike
N55_Mike's Avatar
Drives: 135i, Z4MC, MK7 GTI
I got a FCAB press tool of Amazon, recently used it to install my Powerflex FCAB's. Worked great! Here is the link to it :
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      07-25-2016, 05:53 AM   #3
GuidoK
#buildnotbought
GuidoK's Avatar
10855
Drives: Z4 3.0i ESS TS2+
I have that universal kit. Thats a great kit to have.
If you're just going to do the fcabs and never any other bushings, you're better off buying a kit specific for the fcab's (faster, you dont have to wind in the long threads), but if you think you'll do anything else, ever, get that universal kit.
I polybushed my complete rear axle with it, all 17 pressed bushings in less than 3,5 hours (less than 15min per bushing) so it's very versitile as theyre all different sizes and does the job. Buying the specific tool for each and every of those bushings would have cost me thousends.
      07-25-2016, 08:59 AM   #4
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
Thanks. I already have this tool, but don't see how it helps press the bushing in/out of the lollipop. Did you have the bushing pre installed in the lollipop?
      07-25-2016, 09:03 AM   #5
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
Thanks. Addng tools to the collection...hmmmm, let me think.
      07-25-2016, 02:05 PM   #6
N55_Mike
N55_Mike's Avatar
Oh my bad haha, you can't push it in/out of the lollipop. I had a local shop press it in for me.
      07-31-2016, 09:47 AM   #7
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
So, ummm... having removed the old fcabs I see that the new superflex bushings are quite a bit taller than the oem bushings. I assume that the new bushings should still be centered in the lollipops? That is, equal amount of bushing sticking out of the lollipop on both sides? Or do I have the wrong bushings?
      07-31-2016, 11:44 AM   #8
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Correct, they center in the lolly
I also found that there were no index markings, so made my own index markings to align the offset properly.
      07-31-2016, 12:05 PM   #9
GuidoK
#buildnotbought
GuidoK's Avatar
10855
I see you bought that universal kit (if I interpret the blurry stuff in the background). So it did the job? (seeing a single used busing )
      07-31-2016, 12:24 PM   #10
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
Good eye! Yes, it worked great for pressing out the bushing, once I cut out enough of the old bushing so I could get the threaded rod down the middle. (The M has offset bushings.) Not so much luck pressing in the new bushing though. They keep slipping and getting jammed at an angle. I think I'll have to find a press or have a shop press them in.
      07-31-2016, 12:28 PM   #11
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
Thanks! In rereading your old post on these I take it you used a vise to press in the bushings? Can you provide more details on the technique you used?
      07-31-2016, 12:34 PM   #12
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
with a vise you still need a cup for it to push into....
Its OK for a one time job.
I have the universal kit now that Ive ended up doing a few.
      07-31-2016, 12:52 PM   #13
GuidoK
#buildnotbought
GuidoK's Avatar
10855
Also if you use the cups upside down? (so that you have a flat surface to press against the bushing and lollypop).
If you then want to tighten the nut, you must either have long sockets with a hex on the end, or you put another cup inside to raise the nut.
Oh wait, it obviously has to fit with the offset center. Maybe the biggest cups?
I can imangine that the load is distrbuted unevenly because of that offset center and that that is a pain.
Maybe you can get them started in a vise.
Also to press them through with the offset center might be a challenge (the part where the bushing will come through the lollypop). Either in the vise or in a press.
You can use the cups under a press too obviously.
Having the cups is already half the challenge to press fit something under a press too.
      07-31-2016, 03:10 PM   #14
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
The superflex bushings have a removable core. The hole is large enough, even with the offset, to get the rod through, so no problems there. Clever design, and I assume it also removes any twisting load that might otherwise be placed on the bushing. I'll try with the cups reversed as you suggest and see if I have better luck.
      08-03-2016, 01:59 AM   #15
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
Just to wrap this up. Spent a couple of hours trying to get the bushings pressed in with the cups and threaded rod. Just couldn't get them to stay straight. Would go crooked every time. I went to a local diy shop and used their press. Done in 15 minutes. All buttoned up and ready for thunderhill this weekend. Hoping the front end squirm braking for T1 is gone!
