05-22-2010, 03:37 PM | #1 |
Rep 1,143
What the...jackpoints?
Is it me, or am I missing 2 jackpoints?
Here's what the back looks like: Here's what the front looks like: Looks like the rubber part of the jackpoint was removed at some point....or is this some sort of silly M feature? Both sides in front look like this. More importantly, is it still safe to use that part of the front as a jackpoint without the rubber part? |
05-22-2010, 03:45 PM | #2 |
Rep 698
Yea, you're missing some.
I wouldn't jack without the pad.
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
05-22-2010, 04:08 PM | #3 |
Rep 31
Drives: 05 Z4 3.0i
I recently found the front of my car was missing one as well. The parts guy at the dealership said they fairly commonly were dislodged. They had them in stock for $27.85, part# 51-71-8-268-885
2005 Z4 3.0i roadster, Merlot red metallic, beige int & top, sport, premium, heated M seats, xenons, Aux input, OEM strut brace, OEM hard mount wind diffuser
05-22-2010, 04:32 PM | #4 |
BMW Fan
11
Rep 553
yes, you can jack there using a small block of hard wood. You won't be able to use a jackstand though. You can also lift both sides using the front center jack point which is a round piece of hard rubber at the front edge of the aluminum under body panel.
05-22-2010, 05:09 PM | #5 | |
Rep 1,143
I'll see if I can get to the front center jack point. How far in from the front is it? Would a regular hydraulic jack be able to get access? |
05-22-2010, 05:16 PM | #6 | |
Rep 4,320
Drives: '07 Z4 M Coupe
You really can't reach it from the front, so I've always raised the rear first then used a Craftsman floor jack coming in behind the front wheel to reach the front center jack point.
05-22-2010, 08:20 PM | #8 |
Certified Adrenaline Junkie
43
Rep 1,325
I built little ramps out of a 2x10x10 and jack from the center jack pad. Added little rubber stoppers to keep them from sliding when I drive up on them.
05-23-2010, 07:45 AM | #9 |
Rep 1,545
+1 except I'd use a hockey puck instead of a wood block until the replacement part came in.
- Jeff
bosstones' flickr |
05-23-2010, 12:35 PM | #10 | |
Rep 666
http://www.bimmerfest.com/forums/sho...27&postcount=3 If properly installed with the center locking pin fully inserted the Z4 jack pad is very difficult to remove without removing the locking pin. Since the jack pad occupies the place where you insert the tie-down T-hook I modified the jack pad so it can be levered out without removing the locking pin. Haven't lost a jack pad yet http://www.bimmerfest.com/forums/sho...light=jack+pad I carry four T-hooks so the car can be properly lashed down for flatbed towing. I've seen too many tow truck operators lash down BMWs using straps wrapped through the wheel spokes or around suspension components. http://bimmerfest.com/forums/showpos...94&postcount=1
Jim Millet
05-23-2010, 05:28 PM | #11 |
43
Rep 1,325
Tried to purchase some from AWdirect, no luck finding part PD1. Do you have a newer part number?
Did find these tho. http://www.awdirect.com/tie-down-hooks-ca13/hooks/ Do these look like yours? |
05-23-2010, 05:35 PM | #12 | |
BMW Fan
11
Rep 553
http://www.awdirect.com/tie-down-hooks-ca13/hooks/ Turner sells the jack pad for about half of what the rip off dealer wanted http://www.turnermotorsport.com/html...ID=51718268885 Last edited by AWM3; 05-23-2010 at 05:47 PM.. |
05-23-2010, 06:07 PM | #13 | |
Rep 666
You can find your towing specs here: http://www.towspec.com/vehent/unsecure/
Jim Millet
02-27-2011, 05:39 PM | #15 | |
More of this than that!
29
Rep 817
'06 Z4 3.0i Jet Black/ Biege/Black Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector |
02-27-2011, 06:51 PM | #16 |
Engineer
216
Rep 2,122
Drives: M235I 2015, 335i 2011
I have 4 of this if you guys need
02-28-2011, 08:43 AM | #17 |
Rep 822
If you jack the car from the rear pad it will lift the whole side of the car.
SoCal Z Enthusiast contact me to get on the list. Events for like minded people and when you talk about your Z, we will know what you are saying. https://www.facebook.com/groups/ZSCCACalifornia/
02-28-2011, 09:56 AM | #18 |
Rep 597
Drives: M4, R8, Huracan - All topdown
Garage List 2018 Audi R8 V10 Sp ... [0.00]
2021 BMW 330e xDrive [0.00] 2017 Lamborghini Hu ... [9.50] 2016 BMW M4 Convert ... [0.00] |
Sorry to go off topic. Anyone have opinions on this?
I have seen them listed on ebay for around $40. Is it worth it? |
02-28-2011, 10:19 AM | #19 |
Rep 6,381
I am missing all 4, I'll take these if they haven't been claimed yet.
Apparently the Z4 loves to shed parts because I thought I was the only one missing these. I also thought I was the only one missing a couple of the little plastic interior pieces on the vents and doors but a fellow member confirmed his were missing as well! Same with the battery cover clips!
Nikki
02-28-2011, 11:33 AM | #20 |
Rep 2,782
Yeah, you could say the brake cooling ducts and I had a "falling out." The first one is somewhere on 46, and the second decided to unseat itself and get munched by the tire. Btw, nice signature. Where did you get the pic?
02-28-2011, 11:49 AM | #21 | |
Rep 6,381
Thanks, I stole it from here and edited it: http://www.flickr.com/photos/victory...7625979001939/
Nikki
02-28-2011, 12:00 PM | #22 | |
Rep 141
