06-03-2011, 09:51 AM | #24 |
Rep 606
Big fan! Is there any ability to have the wing sit lower? By maybe 4-6 inches?
My car is about as track prepped as you can get -- half-cage, harnesses, race buckets, etc -- but I still think having a big wing like that on the street (yes, I do drive on the street) is a bit out of place. On the track, AWESOME. Motoring around city streets, meh...
|www.onehotlap.com|Real People|Real Cars|
06-03-2011, 04:18 PM | #26 | |
1821
Rep 5,337
IMO (here we go again), unless there are significant weight reduction from both ends, this car does not need aerodynamic aid since the drag will reduce the available HP, and at 330 you're going to need every HP you've got to move 3,400+ lbs (trust me, unless you weight 120 lbs, the car is going to be over 3,400+ lbs). Club racers that ran any sort of significant wing(s) like this typically weight in at around 2,600 lbs or less with driver, and has enough power AND grip to require down-force. Frankly, these wings on anything outside of cars modified for competition, are mostly for looks only. Very few will be going at 90mph+ through a turn only to find that their car is too light to have any significant grip on either end.
06-03-2011, 05:17 PM | #28 | |
Rep 1,663
Hack, how do you feel about front splitters?
06-03-2011, 06:53 PM | #29 |
M = Midlife Crisis
66
Rep 2,006
2006 Z4MC - #LL93158
06-04-2011, 12:02 AM | #30 |
1821
Rep 5,337
Again, it's simple. At 3,200 lbs these cars don't have any significant need for down-force. There's not enough lift on either end at speed to really have the need.
Where any form of splitter/endplate/giant wing will come in handy, is when you're competing with a heavily modified car with a lot of weight reduction AND fat @ss tires. When you have this particular combination, like 500-600 lbs removed from this car, with a ton of power, you CAN and will experience loss of traction and some of that negative effect of aerodynamics causing loss of grip (since less weight = less grip). In practical terms? They're useless for 99.9% of the population. Heck they're probably useless unless you get to the Modified class in BMW CCA Club Race, or some of the "unlimited" classes where massive weight reductions are allowed with CF panels and lexan glasses and completely stripped cars. However, with a front splitter, there IS less drag penalty compared to giant rear wings, so you'll see a lot of Prepared class cars run them because, well, every bit of added grip helps. So if we're strictly talking about the splitters up front, or extended end plates, they're certainly more helpful than full-on wings. But they (wings and splitters) sure look good. I'd rock it whether or not they improve my lap times.
06-04-2011, 12:48 AM | #31 | |
Rep 245
Drives: fairly quickly.
I'm not looking to get into a pissing match here, but I kinda have to take issue with a few of your points, on both an academic and practical sense. I agree with you that most people don't need aero on their cars, but that said, some of your points are sweeping generalizations, and distract from what I think you are trying to get at.
As someone with a fairly in-depth knowledge of car setup and tuning, the tuning options available to a car with aero greatly outweigh the options of a car without. Especially because once you start spending the money to get a functional wing (APR, Voltex, Varis, etc) you can always change the AOA of the wing.
"It will not have enough power until I can spin the wheels at the end of a long straight in top gear."
-Mark Donohue |
06-11-2011, 04:55 PM | #32 |
DHS
222
Rep 4,037
Not really a fan of the huge wing but if it actually serves a purpose then I give a thumbs up.
I am finally able to see a black Z4M with black TE37s and must say I do not like the look at all. Not trying to be a jerk but I had not seen one lowered and I almost bought a set and will not be buying a set now. CE28s look a lot better on this car IMO. Thanks for the pictures.
2023 BMW M4 2016 X3 |
06-18-2011, 01:46 AM | #33 | |||
Rep 48
PM me for more details. Smaller profile/shorter wing stands are available. Quote:
If you look at time attack cars they all run as much aero as allowed in their classing, even in street class where the contenders are privateers with low budgets. Aero is effective regardless of the power output, your cornering speeds are faster, thus you carry more speed throughout the whole track. A good example is a Honda S2000's with ~190whp turning 1:57's on street tires at BW CW13. A wing/splitter setup on my 3300lb M3 at 280whp gained me roughly 5 seconds at BW CW13, same tires/brakes/driver. The argument of weight/power vs drag maybe valid on a long straight but even then it would be a coin flip since with aero your cornering speeds are higher so upon corner exit the aero equipped car will be at a higher speed. Quote:
All Varis does is make stands/mounts for cars and they label it theirs. |
11-03-2011, 01:44 PM | #35 |
Accountant, 1st Class
Rep 237
Drives: 2006 Z4 3.0si Roadster, Black
Winged ///M
No no no no head lowered shaking head back and forth no no no no
"I was always told if you drive a roadster with the roof up, the storm outside better have a name", Mikedav, UK
11-11-2011, 12:14 AM | #36 |
Rep 701
Just when I thought I had seen it all.
When do you turn 21?
12-14-2011, 04:41 AM | #39 |
Rep 9
Awesome look, how i hate the german TÜV (mean guys who say "no" to every parts which look nice).
But why is there a german license plate under the american? Big mistake to sell your car with your license plate :/ |
Tags |
aerodynamics, platte forme a.g., platteforme, splitter |
