06-17-2012, 03:17 PM | #23 |
Rep 4,531
06-17-2012, 08:11 PM | #24 |
Rep 12,567
Yes, if anything just like oe bolts, these should be replaced every few years. Hence I plan on getting mine redone sometime this summer.
06-17-2012, 09:54 PM | #25 |
Rep 208
Good question - I asked the same...
The kit I got from Vorshlag came with two small resealable tubes of the following, in factory packaging ... 1) Vibra-Tite Anaerobic Threadlocker Permanent Strength RED 13102. The packaging says "Compare to Loctite 262". The cure specs of Loctite are here - http://tds.loctite.com/tds5/docs/262-EN.pdf 2) HD Industries Copper Anti-Seize 907C |
06-18-2012, 02:11 PM | #26 | |
instagram 997turbotom
284
Rep 7,377
I don't mind if I break my torque wrench. Its a big Harbor Freight model that caused me to break a spark plug before. I really like the idea of a cordless impact wrench to save time
06-18-2012, 02:30 PM | #27 |
Rep 208
My Milwaukee cordless impact wrench (a Christmas present from my wife) with NiCD is rated at something like 100lb/ft. It's not quite enough to "break" the nuts that are on even though I hand torque them to about 85, thus the extra breaker bar. Don't know if a cordless with a beefier motor/battery would eliminate the need for a breaker bar. If so, don't overtorque.
08-14-2012, 02:38 AM | #29 |
Rep 701
This thread just reminded me to get around to doing this simple but effective modification.
08-14-2012, 08:30 AM | #30 | |
Rep 4,531
It has cut my time in half (now around 20-30 mins for all 4 wheels...including the time to set-up my air impact), so easy to just throw the wheel on the stud and hub, tighten the first lug and it's centered and ready for the other 4. |
08-14-2012, 10:38 PM | #31 |
Rep 701
Now if only we had centre lock wheels we could cut that time down to about 20sec per corner.
